Mechanical Water Temp Gauge
I am trying to install a water temp gauge in my 61 394 and there appears to only be one spot to put it. I would like to keep the original temp sensor in. Has anyone got any ideas? I don't want it to look stupid. They must make a "T" fitting that allows you to do this.
Pat
61 Olds 2dr sedan
Pat
61 Olds 2dr sedan
Pat
61 Olds 2dr sedan
Pat
61 Olds 2dr sedan
Would there be some un-used bungs in the front water crossover that he could use? I am not familiar with the 394 manifold but can remember that there are some on 455s depending on how many additional "valves and/or sensors" are or are not used.
I suggest you install the new coolant temp sensor in the spot where your old one is at. If you want to keep the functionality of your HOT / COLD dummy light then all you have to do is go to Radio Shak and get a simple logic circuit. You would need a circuit to apply ground or 12V (whichever was switched by your old sensor) to your original temperature lights based on the voltage of the new coolant temp sensor. It sounds complicated but you should be able to find something like that at Radio Shak or on the internet.
