455 Rear Main Seal
Old Jul 20, 2007 | 08:10 PM
toneypenna's Avatar
455 Rear Main Seal
Does Any Body Make A Ruber Lip Rear Main Seal That Replaces The Rope Seal?
I Know They Are Made For The Earlier Blocks Pre 64.
Any Help Would Be Appreciated.
Jim
Old Jul 20, 2007 | 10:07 PM
Beeterolds's Avatar
use the fel-pro rubber rear main seal for the 460 Ford it works great!
Old Jul 22, 2007 | 09:06 AM
toneypenna's Avatar
455 Rear Main Seal
Beetterolds
Thanks for the tip.
Jim
Old Jul 22, 2007 | 10:30 AM
Beeterolds's Avatar
http://store.summitracing.com/partde...2&autoview=sku
Old Jul 22, 2007 | 01:38 PM
toneypenna's Avatar
455 rear main seal
beeterolds
Thanks again, now I have a part #
Jim
Old Aug 2, 2007 | 06:45 PM
1971442convertible's Avatar
admittedly very green so go easy. why/how is it that a ford seal works on the olds? and can this be changed with the engine in the car?
Old Aug 2, 2007 | 07:06 PM
don71's Avatar
same but different
By coincidence, the sealing area of the two crankshafts share dimensions. Some parts suppliers actually carry a rubber seal listed for olds, its the same, just ask at one of your local auto parts store.
As for changing the seal with the engine in the car , its a real challenge. The transmission would need removal. One of the motor mounts would need to be loosend to remove the oil pan. Probably best to replace the seal with the engine out of the car. But thats my opinion on how to do it.
Old Oct 6, 2010 | 02:38 PM
tuna's Avatar
Just bought a seal from BOP suppose to be the best. I hope so, the engine is out now and I don't want an oil leak later!!!! Anyone ever try these seals???
Old Oct 6, 2010 | 05:15 PM
442Harv's Avatar
Have used the Ford seal at least 4 times. To do it right, the crank should be polished good. The last one I put in, while having the crank turned, I also had the Kneals removed. I have also installed as is and had no problem.
Old Oct 7, 2010 | 05:19 PM
ziff396's Avatar
I also used the 460 seal with no problems or leaks to date.
atkinsom
Feb 28, 2019 06:16 AM
zekecut70
May 13, 2015 02:49 PM
atkinsom
Jun 11, 2014 07:14 AM
65cutty
Sep 23, 2008 10:07 AM
gearheads78
Apr 17, 2008 05:03 PM
