HEI Distributer
Old Dec 31, 2006 | 06:39 PM
mcutlass1969's Avatar
HEI Distributer
Need to know if I have an HEI Dis out of a olds 350 if it would work for a 455. I was able to get it placed but doesn't seem to drop the last 1/4 inch.
Old Jan 1, 2007 | 08:39 AM
texasred's Avatar
Tom Servo's Stunt Double
Same distributor. Sounds like the teeth aren't meshing. May I suggest you get it to start seating (distributor shaft starts to mesh with the cam gear and won't turn) and GENTLY tap on the distributor shaft with a rubber or rawhide mallet.
C.J.
Old Jan 1, 2007 | 02:10 PM
64Rocket's Avatar
Sounds like the oil pump shaft is not lined up. You may have to bump the engine or turn it with a socket on the front damper . Just turn it a little until the shaft lines up. Make sure you have the rotor line up with #1 plug wire when it seats. I don't think beating on it is going to help.
Gene
Old Jan 1, 2007 | 11:15 PM
texasred's Avatar
Gene,
Good thinking! But I wasn't suggesting "beating on it". I had problems seating mine and a little "friendly persuasion" helped.
And remember that the distributor shaft rotates slightly as it seats completely.
C.J.
joepenoso
Jun 4, 2014 01:56 PM
scrappie
Feb 11, 2014 07:03 AM
charlierogers
Apr 8, 2012 04:54 PM
charlierogers
Apr 8, 2012 10:08 AM
kenny
May 17, 2010 01:08 PM
