Valve seal 394
Old Jul 31, 2009 | 02:35 AM
rs2600's Avatar
Valve seal 394
Can the valve seals easily be changed without removing the heads? Any special tools required?
Thanks,
Matt
Old Jul 31, 2009 | 05:08 AM
rocketraider's Avatar
Oldsdruid
It can be done with heads on the engine.
You'll need a spark plug hole air chuck tool (and air compressor) to hold the valves shut while you're working so the valves don't drop into the cylinder.
You'll also need a lever-type valve spring compressor. You may be able to rent both tools from a parts store.
You'll have to remove the rocker shaft, then use the spring compressor to remove the valve keys and springs. Once those are out of the way, you can install the new valve seals. Valve adjustment is automatic on reassembly.
Old Jul 31, 2009 | 06:45 AM
rs2600's Avatar
Thanks, just what I wanted to hear.
Matt
and1stp
Nov 4, 2023 07:42 AM
esisson
Jun 7, 2023 07:44 AM
fv64olds98
Feb 11, 2013 10:39 AM
trackz man
Jul 17, 2011 10:08 PM
Sixoh
Aug 8, 2006 05:11 AM
