455 with a Small Block Intake
Old Jul 29, 2009 | 06:56 AM
Schober Motorsports's Avatar
Well when I bought my F85, the seller gave me loads of extra parts. One of the parts he gave me was an Edelbrock intake for the 330. So I started doing some research and later found out that small blocks and big blocks have a lot of interchangeable parts. So now I got this intake and buying a 455. Is there anyway of putting this Edelbrock on to save me a few hundred dollars? Thanks in advance
Old Jul 29, 2009 | 07:25 AM
gearheads78's Avatar
car guy
Not even close. The deck height is higher which speads the heads apart. Sell the one to have to offset some cost.
Old Jul 29, 2009 | 07:51 AM
Yeah, spend a couple of hundred dollars having custom spacers machined.
Old Jul 29, 2009 | 08:51 AM
cutlassefi's Avatar
455 manifold
I agree, lots of good correct manifolds for the 455. Sell the other one.
Old Jul 29, 2009 | 09:46 AM
Ok thanks for the help.
Another question I have. I am buying a old boat that has a rebuilt 455 in it. Now the boat is a jet boat, is there any difference in the crankshaft from a car motor or is there any differences from a Olds 455 marine motor and an Olds 455 for a car? I am asking cause I don't know anything about boats/jet boats or anything of the sort. I actually want to scrap the boat and take the motor.
Old Jul 29, 2009 | 09:49 AM
I don't believe there are any differences in the Olds motors that were put in boats. Except externals like carburetor, exhaust manifolds, distributor, etc.
Old Jul 29, 2009 | 12:02 PM
citcapp's Avatar
If its now in a boat you will get a flywheel thats never had a clutch touch it and a crank drilled for a stick transmission. Easy to use in a conversion to a four of five speed stick in you car.
Couple of other things
1. You can sell the exhaust manifolds to boat guys and get part of your money back
2. Same goes for the jet drive
3. You will most likley have to install a water pump
4. You will most likley have to change out the oil pan and pickup tube for the oil pump as the boats used a flat bottom pan that won't work in your car.
5. Most boat engines have Ka heads which are good heads.
Old Jul 29, 2009 | 07:19 PM
Ok last question until I think of another one!
I have a pair of high compression heads (385101) for a 330. I am looking to make a racing motor. Could I possibly use these heads on a 455? What would I have too do to be able to use them on it.
Old Jul 30, 2009 | 06:59 AM
The 330 heads will physically bolt to the 455. The 330 heads have smaller ports, smaller valves, and smaller chambers than those on BBO heads. The smaller valves and ports will hurt flow. The smaller chambers will result in a very high compression ratio. Not a good idea.
Old Jul 30, 2009 | 11:49 AM
svnt442's Avatar
That and I think the BBO intake runners will extend over the material on the SBO heads and wouldn't seal.
Old Jul 30, 2009 | 12:10 PM
Ghost Post's Avatar
SuperMod
Doubtful it's a problem especially being a single engine boat but w/ any marine engine always make sure it's not a reverse rotation unit!.
~ Pete
Old Jul 31, 2009 | 10:27 PM
Redog's Avatar
Which mani is it?
I'll pay shipping if you want to send it to me
Old Aug 1, 2009 | 08:45 AM
zed's Avatar
zed
Or a bucket of JB Weld... LOL
bocoogto
Aug 26, 2023 06:09 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
citcapp
Jan 31, 2009 04:01 PM
