W-30 Timing Advance
Old May 25, 2009 | 12:30 PM
7.5 Litre Nightmare's Avatar
Smile W-30 Timing Advance
Hey guys, brand new to the forums here. Hope ya'll are having a great memorial day. I have a question about a 455 motor. It's a W-30 out of a 4-4-2 and I was wondering if anyone knew what the advance should be ? It's got a Melling W-30 cam and an Accel HEI distributor. Any help on this would be appreciated.
Old May 25, 2009 | 01:41 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
With the vacuum advance lines plugged, I think 25 @ 3000 rpm should run well.
Then hook up your advance and see how she runs.
Back it off if need be.
Old May 25, 2009 | 01:42 PM
That's what i run mine at, but i'm using a points advance. I'm not sure if hei adds more .
Old May 25, 2009 | 10:15 PM
Run to Rund's Avatar
I suggest 12 deg. initial without vacuum advance hooked up. For an automatic, bring in the total of 36 deg. around 3000 rpm. For a stick around 4000 to duplicate stock curves. You can mix and match Mr. Gasket etc. springs to get the advance you want. After you are done, hook up the vacuum advance.
Old May 26, 2009 | 05:32 AM
Thanks J and Rund. I will give that a try and see how it runs.
Old May 27, 2009 | 09:02 AM
1964f-85's Avatar
get an aftermarket adjustable vacuum unit, start at full advance them back it down to eliminate the pinging at part throttle. i would run as much as the car can handle.
My mild built 455 likes very little advance, but every Olds I have owned is different.
Old May 28, 2009 | 05:56 PM
pitfield1's Avatar
I got this from my super tuning "W" booklet, and I quote.."Basic stock setting of 14* BTC at 1250 provides 27* BTC timing above 4000 rpm" Hope this helps,and welcome.
PIT
69 442 conv
Old Jun 1, 2009 | 07:37 PM
88 coupe's Avatar
Junior Member
Originally Posted by 7.5 Litre Nightmare
........ wondering if anyone knew what the advance should be ? ........
Post #4 works for me.
Originally Posted by J-(Chicago)
........ i'm using a points advance. I'm not sure if hei adds more.
The method (mechanical or electronic) of triggering the coil has nothing to do with the timing of the spark.
Norm
Old Jun 3, 2009 | 07:01 AM
70Wcars's Avatar
Good answers here.
Welcome Back Norm..missed your knowledge...finally got my race car in the 10's...
Danny
Old Jun 3, 2009 | 08:34 AM
88 coupe's Avatar
Junior Member
Originally Posted by 70Wcars
........ Welcome Back ........ finally got my race car in the 10's.
Thanks and congratulations.
Get me a pic to post when someone badmouths the Q-Jet.
Norm
pcard
Feb 11, 2013 05:09 PM
AZ455
Aug 30, 2012 05:52 PM
jensenracing77
Aug 18, 2012 08:06 PM
442scotty
May 13, 2009 05:42 PM
1FSTLS1
Jan 1, 2009 02:39 PM
