cam ??? JM-20-22
Old Apr 7, 2009 | 07:12 PM
0590trab's Avatar
cam ??? JM-20-22
Hi, guys I am needing to know can i run a JM-20-22 with stock valvetrain
1969 olds 455 bored over .040 / C heads / L2323F pistons
jm-20-22
Lift .496 intake
.512 exhaust
dur: 226/230 @ 50
LC 110
the mondello parts book list it in the manual as usable w/ stock rocker
just wanted to know what you guys think...
thanks in advance for any help you give.........trab
Old Apr 8, 2009 | 04:29 AM
My442's Avatar
I have run that cam in 2 different engines.
You will need to rejet the Q-jet and recurve the distributor.
I get 16" of vacuum at idle, so it works with power brakes.
Used the Comp Cams roller tip rockers.
Old Apr 8, 2009 | 10:51 AM
Bobsw32's Avatar
BobsW32
I have found that stock rockers are very inconsistant with their ratio.
If you are going to use them I would check them to make certain they all give the same valve lift......Also I hope you are going to install new springs.....Old springs get very tired.......then you will need to check the lifter pre-load as it may very well have changed........and the stock system is non-adjustable so the only way to adjust the rockers is by milling the pedestals or shimming the pedestals depending and which way you should go...
Old Apr 8, 2009 | 07:26 PM
0590trab's Avatar
Thanks Guys, I had a comp cam 292H in this engine, it did not work well ,it mushroomed the bottom of the lifters, rounded off the lobes on the camshaft, bent a few pushrods, so Iwas thinking this JM-20-22 was a little bit smaller, i had heads redone the vavle springs came new w/ comp cam kit,so they are in great shape, so the engine builder said. anyway thanks again for all the help............trab
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
72RocketPower
Aug 11, 2005 04:51 AM
Rocketman
Nov 22, 2004 01:59 PM
