455 Roller 72 Cutlass 455
Old Mar 27, 2009 | 10:01 PM
egknz's Avatar
1972 Cutlass Supreme 455
can you make a 455 Olds Mtr a Roller ?? and what about a serpentine setup ?? if so what are the specs ????
Old Mar 27, 2009 | 11:05 PM
trdbrd's Avatar
Roller cam im guessing, if so yes. My friend that has been helping me with my olds runs a similar solid roller to the one in my 492 pontiac. Not sure on his specs but I know his lift is similar to mine .736" lift. Keep in mind if your heads dont flow at those lift numbers its a waste. Match your cam to your head flow numbers.
Old Mar 28, 2009 | 06:15 AM
Yes, you can buy aftermarket roller cam/lifter setups for an Olds. The stock late 307 roller lifters won't work in a 455 because the diameter is different (0.921" for the rollers vs. 0.842").
The only "serpentine" belt kits are aftermarket ones that use the conventional water pump and a bazillion idler pulleys to force enough belt contact. In my opinion these kits are a complete waste since they are more complex and create more HP loss than the stock V-belts. The only reverse rotation water pump ever made for an Olds motor is the one on the V6 diesel. There are a couple of true serpentine kits made for the Olds-motored GMC motorhomes using this pump, but the accessory brackets are low and wide to fit that application. Plus, these motorhome kits cost more than I paid for many of my cars.
(Why? Because they can. One vendor refuses to sell the reverse rotation water pump separately, and refuses to admit it's the diesel pump. I bought one new on RockAuto for $35 or so.)
Old Mar 29, 2009 | 09:54 PM
70_CS's Avatar
torque machine
i perfer the 1442 kit from comp cams
Old Mar 30, 2009 | 08:23 AM
citcapp's Avatar
I run full roller cam, lifters, and rockers in my 455 in my 57 and like them a lot. Just my opinion
Old Mar 30, 2009 | 08:36 AM
cutlassefi's Avatar
Roller 455
I agree. Have a full roller (hyd) setup in my '72 350. Wouldn't change it for anything.
Old Mar 30, 2009 | 08:51 AM
trdbrd's Avatar
That 57 must flat haul ***. Have you brought it out the the BOP drags/car show at Bremerton ? Its a good time with good friends.
Old Mar 30, 2009 | 09:22 AM
nonhog's Avatar
Registered car nut
I goofed and missed that last fall. Wouldn't have been ready to race, may not next fall either but want to go !
the plan is to see how my (not yet powered by a) 455 65 Cutlass does vs. my bro in law's 66 skylark with a 455 (Buick of course) .
So citcapp run it ? going to ?
Old Mar 30, 2009 | 01:09 PM
citcapp's Avatar
Yeah it does haul the freight some fun big car and all. No I haven't been to the BOP drags/car show when is it? I want to run it at least once just let it all hang out
Old Mar 30, 2009 | 02:02 PM
trdbrd's Avatar
Its in September, I'll take a look at the track calender when I get back to the shop. Look me up if you go. I'll have the 64 done for it and I'll have the 67 Firebird, big solid roller in this car for a stock block pontiac. Though I do run a lifter bore brace and have the block epoxy filled.
Old Apr 1, 2009 | 10:45 AM
cutlassefi's Avatar
Roller Valvetrain
Good news everyone, Lunati now has Olds Hydraulic roller lifters at a price below Crane and Comp. I get em for about $100.00+ less than the others.
It's a step in the right direction!!!
Old Apr 1, 2009 | 10:52 AM
Oldsguy's Avatar
Past Administrator
Wow! that is cheap!
Old Apr 1, 2009 | 11:35 AM
citcapp's Avatar
Thanks I will look into that as it is my next purchase for the 455 I am building for the 48 Olds
Old Jul 21, 2009 | 01:09 PM
nonhog's Avatar
Registered car nut
Its in September, I'll take a look at the track calender when I get back to the shop. .
any word on the BOP races ? I'm coming up empty online searches
thanks !
dfire25
Feb 26, 2013 07:36 AM
sethj78
May 2, 2012 02:06 PM
sethj78
May 1, 2012 10:48 AM
skryla
Dec 2, 2011 01:12 PM
Redog
Aug 14, 2008 06:56 PM
