Vacuum Type
Old Mar 17, 2009 | 04:55 AM
DAN76's Avatar
Englishman
Vacuum Type
Just looking at the Edelbrock Carb Installation Video and i'm presented with 2 different vacuum ports.
Can you tell me if the 425 Super Rocket (1965) uses "Ported/Timed Vacuum" or "Manifold Vacuum" ?
thanks
Old Mar 17, 2009 | 10:02 AM
70oldsW30's Avatar
To be picky, the motor doesn't use vacuum, it generates it. Various devices on the car use either manifold or ported vacuum. Transmission vacuum modulators, for example, will use manifold vacuum while distributor vacuum advance originally uses ported vacuum. Which is used depends on what device is using it.
Old Mar 17, 2009 | 12:02 PM
DAN76's Avatar
Englishman
OK, so coming from the original Rochester carb, i have a steel line that goes to the trans and a rubber hose that hooks up to the dizzy.
The Edelbrock carb has 2 barbs, one for manifold vacuum and one for ported/timed. Do I simply hook up the distributor pipe to the ported barb and the tranny to the manifold barb??
sorry, this is my first attempt at an intake and carb upgrade!!
Old Mar 17, 2009 | 03:28 PM
Don't forget that your power brakes take manifold vacuum as well. There should be a large port behind the carburetor for your power brakes.
Old Mar 17, 2009 | 04:02 PM
DAN76's Avatar
Englishman
I'm guessing that's the one with the 1/4" brass barb fitting just behind the carb?
Old Mar 18, 2009 | 04:31 AM
Yes
Old Mar 18, 2009 | 07:04 AM
DAN76's Avatar
Englishman
Thanks guys,
Great help as always!
Old Mar 18, 2009 | 09:01 AM
bigoldscruiser's Avatar
2 '66 98's
On the '66, both the distributor and the trans modulator are connected to the ported vacuum. The carb has only one fitting and there is a tee in the line that branches to both places.
Old Mar 18, 2009 | 09:28 AM
DAN76's Avatar
Englishman
yes that's how it's set up on my original carb.
the trans is a metal line that screws in and the distributor hose is t'd off of that.
I guess I should copy this set up on the new carb?
what would happen if i did one to manifold and the other to ported?
DAN76's Avatar
Englishman
Also, are the consequences big if I block off the PCV valve?
Old Mar 18, 2009 | 09:35 AM
70oldsW30's Avatar
Crankcase pressures up and pushes oil out wherever it can push it out at. The more blow-by you have the greater the problem is. I'd advise to maintain the PCV system fullly functional.
Old Mar 19, 2009 | 12:47 AM
88 coupe's Avatar
Junior Member
........ "Ported/Timed Vacuum" or "Manifold Vacuum"? ........
Ported, same as any other Olds with vacuum advance.
........ On the '66, both the distributor and the trans modulator are connected to the ported vacuum ........
You are half right. Distributor does use "ported/timed" vacuum, but the trans (like any other Olds with a vacuum modulator) needs "full time" vacuum to work properly.
From the '66 Chassis Manual:
Norm
Old Mar 19, 2009 | 01:09 AM
88 coupe's Avatar
Junior Member
........ what would happen if i did one to manifold and the other to ported?
Ported to modulator and manifold to advance would work, but not as well as the factory setup. Try it for yourself, it won't hurt anything.
Originally Posted by 70oldsW30
Crankcase pressures up and pushes oil out wherever it can ........
To say that pressure builds is an exaggeration. Fumes would simply escape into the air filter and be sucked into the carb.
........ I'd advise to maintain the PCV system fullly functional.
Good advice.
Unless you like changing air filters, and cleaning oily residue out of the carb.
Norm
Old Mar 28, 2009 | 09:03 AM
DAN76's Avatar
Englishman
[quote=You are half right. Distributor does use "ported/timed" vacuum, but the trans (like any other Olds with a vacuum modulator) needs "full time" vacuum to work properly.[/quote]
took the car out today and it seemed to have trouble shifting up gears.
When i assembled the vacuum lines I put my tranny vacuum hose to "ported", could this be the problem?
Old Mar 29, 2009 | 07:30 AM
88 coupe's Avatar
Junior Member
........ I put my tranny ........
http://www.urbandictionary.com/define.php?term=tranny
Think of the "port" as a valve.
At idle, it is closed and there is no vacuum. Above idle, the "port" opens and vacuum is drawn from the manifold. This combination is needed for the economizer (power) valve and the vacuum advance to work properly.
The "modulator" uses manifold vacuum to control the timing of the shifts.
High vacuum = shifts at lower speeds.
Low vacuum = Shifts at higher speeds.
........ seemed to have trouble shifting up gears ........
If, it does not have sufficient vacuum it will not change gears.
Norm
Old Mar 29, 2009 | 11:05 AM
DAN76's Avatar
Englishman
well that explains that then
thanks
Old Mar 30, 2009 | 12:57 AM
DAN76's Avatar
Englishman
yeah can't wait to take it down the drag strip
http://www.urbandictionary.com/define.php?term=drag
Old Mar 30, 2009 | 07:08 AM
All I can say, Norm, is that growing up in straight-laced New England in the 1960s and 1970s, "tranny" was definitely slang for transmission.
What else COULD it have meant?
Of course, on the left coast, anything goes...
Old Mar 30, 2009 | 09:45 AM
csstrux's Avatar
Old Mar 30, 2009 | 01:07 PM
citcapp's Avatar
Now your slamming my left coast? Man wheres the respect
Old Mar 31, 2009 | 08:13 AM
88 coupe's Avatar
Junior Member
Originally Posted by citcapp
Now your slamming my left coast? ........
Not a "slam". An acknowledgment that everything begins here.
For example, our "speaker of the house" (name withheld, to keep it from becoming political) and "everything" she has been "starting".
Norm
Old Mar 31, 2009 | 09:52 AM
citcapp's Avatar
Got your point Norm
Old Mar 31, 2009 | 10:30 AM
88 coupe's Avatar
Junior Member
Cruise the Sunset Strip in West Hollywood?
http://www.urbandictionary.com/define.php?term=Cruising
Originally Posted by Urban Dictionary
........ Acronym for DRessed As a Girl ........
I never made the connection.
Norm
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
Octania
Mar 13, 2013 09:36 AM
Cuttyon22s
Nov 20, 2006 06:07 PM
Edveen
Jul 22, 2006 12:15 AM
<rebelyel>
Sep 3, 2004 09:30 AM
