Edelbrock Performer and HEI
Old January 15th, 2012, 07:15 AM
mdd71's Avatar
Running a 455 in my 74 Cutlass with the Edelbrock Performer. I would like to convert over to HEI but I hear the vac advance on the HEI interferes with the intake making timing adjustments an issue. True? Maybe Pertronix is the way to go?
mdd71 is offline
Old January 15th, 2012, 08:10 AM
A HEI distributor fits fine. No clearance issues at all.
matt69olds is offline
Old January 16th, 2012, 09:06 AM
Certifiable car addict...
GTI_Guru's Avatar
I dropped an HEI into my '66 425, and it had a slight clearance issue with the intake, but it was easily enough to remedy by rotating the distributor a bit further and then offsetting the plug wires either 1 or 2 spaces to put them back into the right spot for correct timing.
From what I remember, the vac advance wasn't the issue, it was one of the bosses for the cap hold down, or the plastic cap itself that interfered with the intake, but other than that, it worked beautifully.
GTI_Guru is offline
joepenoso
June 4th, 2014 01:56 PM
69CutlassAlex
July 30th, 2013 08:18 AM
olds 307 and 403
January 11th, 2012 03:39 PM
70Cutlass_408
June 24th, 2011 07:55 AM
Quick Reply: Edelbrock Performer and HEI
