Can I install T400 with manual trans crank?
Old June 10th, 2013, 09:28 PM
shamusj's Avatar
Hi Guys,
I have 400 from my old '67 442- it has the manual transmission crank set up.
I'll be installing this motor in my '68 with t400...should i have any worries about mating these two together? Would love to get the gotchas cleared before I start.
shamusj is offline
Old June 11th, 2013, 03:53 AM
Old School Olds
tru-blue 442's Avatar
Shouldn't be a problem.
You would need the flywheel and bolts
for an automatic trans, and good
to go I would think.
tru-blue 442 is online now
Old June 11th, 2013, 04:00 AM
+1. Works fine.
MDchanic is offline
Old June 11th, 2013, 07:14 AM
Just the facts...
BILL DEMMER's Avatar
assuming it's an early 400...
be sure to get the flex plate that is correct for the early big blocks.
after that, you're golden.
bill
BILL DEMMER is offline
Old June 11th, 2013, 07:42 AM
Mikes442's Avatar
I just changed my 4speed to a turbo 400 this weekend in my '67 with NO problems.
After going through all my flex plates I found out how to tell the difference between the 330-400-425 and the 350-400-455 flex plates.
Good for swap meeting.
The 330-400-425 on the counter weight, the piece of metal welded to the flex plate has 8 holes and is cut at about a 45 degree angle on each side.
The 350-400-455 on the counter weight, also has the 8 holes and is cut about square angle on each side.
If I can figure out pictures I will post the difference.
Mike
Mikes442 is offline
Old June 11th, 2013, 08:25 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
wanta sell the 4 speed set up?
droldsmorland is offline
Old June 11th, 2013, 09:33 AM
Mikes442's Avatar
How much of the set up you need?
Mikes442 is offline
Old June 11th, 2013, 10:47 AM
doing the opposite of what your doing in a 68...auto to stick. Console to flywheel all of it.
dan2286
June 5th, 2016 01:05 PM
dads72
March 25th, 2015 03:12 AM
young olds
August 23rd, 2013 05:26 PM
brandon reynolds
April 10th, 2013 07:14 PM
Nor Cal Andy
March 29th, 2012 08:20 PM
Quick Reply: Can I install T400 with manual trans crank?
