Camshaft reccomendations...Stock 455
Old September 8th, 2014, 05:42 AM
cecilsclassics's Avatar
Thumbs up Camshaft reccomendations...Stock 455
I have a stock 1970 455 with C heads, Edelbrock performer intake, 750 Holley and stock manifolds. I am looking for a rough idle cam, as the car is street only and I don't really want to change much. I am basically going for a rough idle and good sound. I don't want to get one too large as the car has power front disc brakes. Looking for some part # help from JEG's. Thanks...
cecilsclassics is offline
Old September 8th, 2014, 08:09 AM
Beer Connoisseur
70cutty's Avatar
Talk to Mark - Cutlassefi here, he has helped many with custom ground cams.
Aggressive cams need more than a stock setup. Higher stall converter, taller gears, higher compression etc. Be careful when selecting of the shelf cam you might lose more than you gain. JMO
70cutty is online now
Old September 8th, 2014, 05:46 PM
rubeng442's Avatar
http://m.summitracing.com/parts/hrs-510991-08
Cheap, should play nice with your stock valvetrain, and it ought to have that choppy idle you want. Get some decent springs while you're at it.
rubeng442 is offline
Old September 8th, 2014, 06:23 PM
cutlassefi's Avatar
Can't help you with a Jegs number but an Erson TQ40 would be perfect, plus it'll work with a stock valvetrain.
cutlassefi is online now
Old September 24th, 2014, 01:52 PM
.Rocket.Man.'s Avatar
I'm looking for the same (rough idle, throatier sound) for my 68 442 with a 400, already equipped with performer intake and edelbrock 750 carb. I am currently running with stock manifolds but would like to go with headers. Any suggestions? Does it matter if car has AC? Any suggestions on Headers as well as cam? Thanks!
.Rocket.Man. is offline
Old September 24th, 2014, 04:29 PM
cutlassefi's Avatar
Compression?
Gear?
Converter?
Old September 26th, 2014, 05:08 PM
Everything is stock, not 100% sure about converter and compression but currently running 3:08 gear, but will be going to 3:42, thanks
Old September 27th, 2014, 07:30 AM
grampy's Avatar
First thing you upgrade is your exhaust then do the rear gear.you will get more get up and go then camshaft change.then upgrade the camshaft.them 68 400 are easy to over estimate camshaft size. How a cam works in 455 acts bigger in a 400.I guess 55 less CI make a diffrencence. As for your performer carb there is a flaw in them the opening of the secondary can not be adjusted. I worked on quite a few them sometimes there is a lean stumble on secondary tip in that can not be tuned out.it better to go back to a quadrajet their are few custom builders for them that will match to your combo at the same price or less than modded holley.
grampy is offline
Old September 28th, 2014, 04:45 PM
cutlassefi's Avatar
Yeah I'd do the TQ40. It'll give you the tone you're looking for.
SkylinesSuck
March 6th, 2015 09:26 PM
Lukewarm
February 25th, 2014 07:09 PM
odddoylerules
24
January 22nd, 2014 06:35 AM
delta254
December 3rd, 2012 08:37 AM
joepenoso
May 13th, 2012 05:26 PM
Quick Reply: Camshaft reccomendations...Stock 455
