469 Carb/EFI build
Old December 16th, 2016, 10:37 AM
cutlassefi's Avatar
469 Carb/EFI build
Doing an EFI BB but did the break in with a carb. Engine specs are;
4.190x4.25 studded and strapped
10.0:1
Custom Lunati 239/244@.050, .580/.576 Hyd roller 112lsa in at 109.
Racetec piston, 1.5, 1.5, 3.00 ring pack
FM 108M mains
Clevite rods
Durabond O6-B cam brgs
Eagle H beams
N crank
My Procomp heads, 2.125/1.68
Hooker 1 7/8 headers
QF 850 Black Diamond carb
Performer RPM w/ bungs and center divider cut 1.00"
It'll be cool to see the difference once the EFI is installed. Should be interesting.......
File Type: mov
cutlassefi is online now
Old December 16th, 2016, 02:33 PM
Mr Nick's Avatar
650 ft/lbs, is this a generous dyno? (no disrespect intended)
Multiport EFI? Holley Dominator?
Mr Nick is offline
Old December 16th, 2016, 03:10 PM
cutlassefi's Avatar
Hey nick,
You always throw out the first and last numbers. They're never accurate.
Don't know if you can see it from the video but yes, multiport.
Even though I'm a Holley dealer as well, I prefer the AEM Infinity. That's what this is getting.
Old December 18th, 2016, 03:13 PM
mrw8i's Avatar
Got to get the rest of the car ready for this build.
Thanks,
Mike
mrw8i is offline
Old December 24th, 2016, 11:07 AM
GammaFlat's Avatar
Wow - Awesome.
GammaFlat is offline
Old December 24th, 2016, 03:09 PM
therobski's Avatar
Mark with a few changes can you get a 425 close to those numbers? We know the 425 has less CI but can rev with a shorter stroke. Can that compensate with the right "stuff".
therobski is offline
Old December 24th, 2016, 05:23 PM
cutlassefi's Avatar
With all due respect, there are a few here that keep throwing the "shorter stroke, rev higher" scenario out there for a 425 vs a 455. Simply not true. A 425 won't automatically rev any higher than anything else if it can't breathe, no matter how much shorter the stroke is.
But if you up the compression, and had better heads you could possibly make up for most of the lost cubic inches. Otherwise apples to apples then no.
Old December 25th, 2016, 07:22 AM
therobski's Avatar
No worries Mark, thanks for the clarification. I have most of the parts to build a 425 and once I get the 64 F-85 in the street with the 400E in it. Then I will get a little more serious on whether the move forward. With the possible option of retiring in 2.5 years don't know if I want to spend the $$$ if the 400E is running good. Merry Christmas!
Old May 30th, 2017, 11:40 AM
Seff's Avatar
Did you ever measure this with the EFI afterwards?
Seff is offline
Old May 31st, 2017, 08:09 AM
cutlassefi's Avatar
Got your email as well.
I did do the same engine on EFI. But the dyno had issues and the pull was compromised. The pull rate accelerated at the end of the pull thereby skewing the numbers.
Fwiw, it showed 522 on the EFI, 541 on the carb measured.
Old May 31st, 2017, 09:56 AM
Seff's Avatar
Cheers, that's what I was hoping for.
Seff is offline
Old July 9th, 2018, 08:57 PM
Kyle's77cutlass's Avatar
Dam!!!! Now that's what I need. Nothing like some old fashion whiplash.
What's the cost of the build?
Kyle's77cutlass is offline
Old July 10th, 2018, 07:10 AM
cutlassefi's Avatar
Let’s just say it’s into 5 digits.
Old July 10th, 2018, 08:05 AM
OLDSter Ralph's Avatar
That's some serious horsepower and torque. I'm guessing the first digit isn't a 9 ?
OLDSter Ralph is offline
Old July 10th, 2018, 08:13 AM
First 2 digits is 19?
Shradezz70S
December 23rd, 2014 06:06 AM
coppercutlass
October 21st, 2012 07:45 PM
Eddie Hansen
March 27th, 2010 08:23 PM
sethj78
September 22nd, 2009 02:38 PM
Oldsproject
May 10th, 2007 06:03 PM
Quick Reply: 469 Carb/EFI build
