425 brackets and pullies
Old May 20th, 2014, 03:26 AM
allen_442's Avatar
So a friend of mine picked u a 425 that used to be in a boat. He wants to to in place of his 350 in his 73 cutlass. Can all the late model brackets and pullies be used if some kind of spacer was used on the harmonic balancer to shim out the pulley? It wouldn't put the engine out of balance in any way would it? Thanks, in advance
allen_442 is offline
Old May 20th, 2014, 04:01 AM
All of the '73 350 pulleys and brackets should bolt on and work just fine, but be sure to use ALL of them, so that everything fits and works.
MDchanic is offline
Old May 20th, 2014, 04:22 AM
Beer Connoisseur
70cutty's Avatar
Make sure that the water pump is the same length as the one on 350, everything should line up then.
70cutty is offline
Old May 20th, 2014, 04:27 AM
allen_442's Avatar
I know the balancer is narrower on the 425 can you shim out the crank shaft pulley so its where it needs to be so everything lines up? He can't use anthing beside the 425 balancer can he? Maybe I'm wrong but I thought on the 330/425 and 350/455 one was internally balanced and one other was externally balance? I hope my question makes sense.
Old May 20th, 2014, 05:25 AM
Forgot about the water pump.
Yes, change that with everything else.
As for the balancer, as far as I know, they're all the same dimensions flange to flange.
Someone else will be able to confirm that for you, or you can just measure them yourself, since you've got both.
MDchanic is offline
Old May 20th, 2014, 08:54 AM
Engine Builder
Smitty275's Avatar
This is correct. Only the outer ring is different. The hubs are all the same length..
Smitty275 is offline
Old May 20th, 2014, 09:37 AM
Octania's Avatar
And, the pulley mounting surface ends up located in the same place, regardless of the balancer used.
NO GOOD can come from putting a shim or spacer behind the main driving pulley. The crank pulley is indexed [located concentric to the crank] by residing on [around] the balancer's slight protruding ring. The bolts cannot be depended on to situate the pulley concentric to the crankshaft. Any sort of spacer or shim over about oh 1/16" thick would cause the pulley to lose contact with the hub's centering ring.
That little bit of spacing can be accommodated by the rubbery belt.
Octania is offline
olddaz
August 27th, 2014 06:39 PM
65cutty
June 25th, 2009 05:44 AM
dan2286
June 23rd, 2009 06:34 PM
olds4life
July 28th, 2008 02:24 PM
jasoneswan
July 2nd, 2008 02:59 PM
Quick Reply: 425 brackets and pullies
