Wheel color
Old Jan 3, 2009 | 09:51 PM
MN71W30's Avatar
Wheel color
What color should I paint the factory wheels on my 71 442? The car is bittersweet and I figured I'd paint them the color of the car.
Thanks,
Dave
I did a search and found an old thread that covered it nicely.
Old Jan 5, 2009 | 06:03 AM
wmachine's Avatar
Trying to remember member
Presume you're referring to steel wheels, not Super Stocks. If it came with dog dishes, the outer wheel and about 2-3 inches over the outside edge into the center get body color. Otherwise black.
Old Jan 5, 2009 | 08:38 AM
MN71W30's Avatar
The car came with 15" ssIII
I plan on using the SSIII wheels that came with my car because they are 15" It also came with a set of 14" SSI wheels with the trim rings. The 15's are a gray color but I might paint them the body color and use them. But I plan on keeping the SSI wheels also now and then. According to the link the SSIII's should stay gray in 71
Thanks for the help.
This is the link I found in the search from Jamesbo.
http://www.oldsmobility.com/superstock.htm#NOTE%205
Old Jan 5, 2009 | 08:55 AM
Some folks are not happy with that link.
Old Jan 5, 2009 | 09:22 AM
rocketraider's Avatar
Oldsdruid
Uh, that was the difference in SSII and SSIII. SSII were Argent Silver and SSIII were painted lower body color.
Old Jan 5, 2009 | 11:26 AM
MN71W30's Avatar
Whats wrong with the link?
Rocketraider, After I read it a few times I figured it out.
Old Jan 5, 2009 | 11:52 AM
I am really not sure why some people don't care of it.
Old Jan 5, 2009 | 05:58 PM
wmachine's Avatar
Just a fine point here. Argent is what is considered the best match to the original color that was actually called "Cast-gray".
Old Jan 5, 2009 | 06:02 PM
wmachine's Avatar
Well, not quite. Because '71 SSII and SSIII were both 14" (14 x 7). You said you have 15".
Old Jan 5, 2009 | 06:49 PM
MN71W30's Avatar
Thats right, A set of 15's came with the car, i figure they must be from a 1974 and I plan on using them. I'm not a huge fan of 14" tires. But I plan on using the SSi's as a back up set.
Old Jan 6, 2009 | 05:22 AM
15" bolt on centers are rare. Guard them with your life.
RAMBOW
Dec 7, 2017 07:22 PM
orence1
Feb 1, 2015 03:14 PM
jvock6
Apr 30, 2012 10:31 PM
classic49
Nov 15, 2007 06:28 AM
Want-A-Vert
Feb 17, 2007 04:20 PM
