Correct block
Old Jul 23, 2010 | 07:22 AM
Thomas Simcich's Avatar
Correct block
66 442 with a third week of July build date (07C). The Julian date on the block is stamped either 166 or 168. Could this be within the build date time frame? Thanks
Old Jul 23, 2010 | 07:25 AM
rcorrigan5's Avatar
Randy C.
Easily. 166/168 is early June. My '68 442 (build date of 04A) has its original block and it is dated in late November (1967).
Randy C.
Old Jul 23, 2010 | 03:15 PM
66400's Avatar
Here's info on a 7B 442.
Block 167
Heads 139
Distributor 6F
Water pump 137
Intake manifold(Tri-Carb) 151
Exhaust manifolds 145 ad 147
Engine unit # V120420T
Henry
Old Jul 24, 2010 | 06:54 AM
Henry, I am not sure about the information you provided. Would you be kind enough to explain those numbers and letters in more detail. Thank you for your help.
Old Jul 24, 2010 | 07:24 AM
66400's Avatar
Originally Posted by 66400
Here's info on a 7B 442. second week of July build date./
Block 167 date code by distributor hole
Heads 139 Date code top surface of head just outside of valve cover lip
Distributor 6F Stamped # on distributor housing June 1966
Water pump 137 Date code cast on water pump
Intake manifold(Tri-Carb) 151 Date cast on intake by #3 runner
Exhaust manifolds 145 and 147 date cast on side of manifold
Engine unit # V120420T Stamped letter/numbers on the end of right side cylinder head.
All casting #'s are Julian.
166 or 168 would likely be original to your car.
Henry
Old Jul 24, 2010 | 11:12 AM
The engine unit number on the head is V121434T, would that number be good?
Old Jul 24, 2010 | 05:46 PM
66400's Avatar
Sounds good to me for a 7C car it follow the numbers on the 7B car.
Had to be one of the last 66 442's built. Total 66 442 production was 21,997 cars.
V1(21434)T
(21,997)
Henry
bocoogto
Aug 26, 2023 06:09 PM
CUT-N-UP
Sep 7, 2013 08:24 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
