69 442 Drums
Old Jul 22, 2010 | 12:30 PM
Cr099's Avatar
69 442 Drums
Hi, new to the site and new to Oldsmobiles...
I have a 69 442 with power drum brakes. I need to replace the front drums. Will 68 442 drums work on my 69?
Thanks in advance
Craig
Old Jul 22, 2010 | 05:14 PM
442Harv's Avatar
I'm not postive about 69. Are the hubs, pressed on to the drums? 68 are, so if , if your's are they will probably work. You can seperate the hubs if you pound,or press the off. What I do a lot of times if I'm not sure what fits what, is to go to my local wrecking yard, and they usally print out a cross over list of the parts you are looking for, and tell all the cars that use the same part.
Old Jul 22, 2010 | 07:45 PM
Thanks in advance
Craig
Yes.
Old Jul 23, 2010 | 06:48 AM
Cr099's Avatar
Thanks guys
Old Jul 28, 2010 | 07:01 PM
tfi racing's Avatar
Too bad you weren't closer!I have a complete drum brake system off of a 68 442,the fronts have been recently redone with new shoes,cyls,hardware,master,rears appear to be good. I switched to an MBM four wheel disc system,I am willing to sell it cheap enough that the cost of shipping may be worthwhile...
Old Jul 28, 2010 | 10:21 PM
Cr099's Avatar
Thanks for the offer. I'm getting some drums locally. If they don't work out, I'll be contacting you for sure...
coppercutlass
Brakes/Hydraulic Systems
18
Dec 6, 2011 01:00 PM
jskosk919
Jul 4, 2006 08:31 PM
JoshF85
Jul 28, 2005 05:15 PM
Sean O'Donnell
Sep 9, 2004 09:54 AM
<crank.it>
May 21, 2003 10:31 PM
