vapor/fuel separator
Old September 28th, 2006, 05:44 PM
rgreathouse's Avatar
hey everyone im new here, my dads got a 1970 442 vert.the other day when we went to take it out we discovered a fuel leak under the tank.we traced it out and found that it was coming off what i believe to be the vapor fuel separator. a fuel line was cracked and one of the male peices coming off of it was cracked, after further inspecting it, it seems to be in pretty bad condition.so my questions are am i correct that this black plastic box with 4 fuel lines coming into it is a fuel vapor separator???it says rochester products gm on it.also where can a new one be purchased,or could it be by-passed?
thanks in advance for any help.
rgreathouse is offline
Old September 28th, 2006, 07:37 PM
ozoneblue's Avatar
fuel prob
Bypass is possible but first see if your fuel cap is vented
ozoneblue is offline
Old September 29th, 2006, 05:26 AM
Past Administrator
Oldsguy's Avatar
First, welcome to our site. Second, try Year One, Fusick, Kanter, or even a Napa dealer. I have found that Napa carries lots of stuff other people don't. I found tune up parts for my '48 flathead six!
Oldsguy is offline
Old September 29th, 2006, 06:57 AM
Tom Servo's Stunt Double
texasred's Avatar
Not to 'jack the thread...but if you remove the charcoal canister under the hood and cap the hose, should a vented fuel cap be used?
C.J.
texasred is offline
Old September 30th, 2006, 08:30 AM
Past Administrator
Oldsguy's Avatar
that sounds right to me. Although I think I removed the canister from my '69 Delta (can't really remember). Did they use them that early? If so, and I did it without using a vented cap, it worked ok, never had fuel pressure problems.
Oldsguy is offline
Old September 30th, 2006, 10:44 AM
ok if it is vented how would i go about bypassing it?
Old September 30th, 2006, 11:27 AM
its not vented can i still bypass the vapor fuel separator?
tomc5
April 20th, 2013 10:44 AM
costpenn
September 16th, 2011 06:50 AM
vmathy
May 31st, 2010 04:32 PM
oldzy
April 6th, 2010 11:22 AM
Wireman134
July 3rd, 2009 04:51 PM
Quick Reply: vapor/fuel separator
