Replacing Manual Window Regulator
Old December 5th, 2015, 10:02 AM
danbrennan's Avatar
Hi, I have a 1972 442 with manual windows, and I want to replace the driver's side window regulator(front). It looks like I might be able to get the old regulator out(and new regulator in) by loosening the track bolts at the top and bottom, and propping the window up some way. Just curious if that's correct, or do I have to remove the window to get the old regulator out?
danbrennan is offline
Old December 5th, 2015, 11:37 AM
It's been a lot time, but if I recall, I just removed the regulator bolts, then fiddled with the regulator and the glass until I could slide the rollers out of the grooves and then slide the regulator out of the door. I think the glass had to be a bit up at one point and a bit down at another point.
MDchanic is offline
Old December 15th, 2015, 05:45 PM
danbrennan's Avatar
I found the trick to getting the regulator out, without removing the window, was to rotate the regulator counterclockwise(with the window up, supported by a couple of 2x4s) until the crank **** lined up with a flare out in the top of the large center hole of the inner door sheet metal, and then the regulator came right out. If I didn't do that, I couldn't get the **** past the sheet metal.
Old December 15th, 2015, 06:42 PM
Octania's Avatar
sounds about right... hold window up with tape or whatnot as need be
Octania is offline
jaybone
April 17th, 2015 09:57 AM
197064buickspec
July 1st, 2014 06:27 PM
tcarroll
December 16th, 2012 11:57 AM
jpc647
January 1st, 2011 07:44 AM
dyscookn
February 6th, 2008 05:44 AM
Quick Reply: Replacing Manual Window Regulator
