did you raise your olds???
Old December 6th, 2009, 04:07 PM
ctrain22's Avatar
Has anyone raised their Olds 442? I know some guys like them lowered, but I don't. I like them raised a little. About 2 inches. Has anyone here done this and waht springs did you use? Pictures????
ctrain22 is offline
Old December 6th, 2009, 09:40 PM
2blu442's Avatar
Many years ago I installed a set of springs that were suppose to lower the car about an inch. Since the springs I was replacing were shot it ended up raising it! So I would first ask the question could it be that your springs are just sagging and if you went with a fresh set of factory springs that it might look right for you? John
2blu442 is offline
Old December 6th, 2009, 10:15 PM
Seasoned beater pilot.
J-(Chicago)'s Avatar
I raked my delta up in the rear a few inches with 75 Fleetwood springs.
It looks awesome and old school on the street, but I'll probably have to swap them back out when I go to the drag strip. I don't see them helping weight transfer to the rear axle very much.
J-(Chicago) is offline
Old December 7th, 2009, 12:29 AM
is Fast Enough ...
mugzilla's Avatar
Check out your actual hieght ...
https://classicoldsmobile.com/forums...tml#post127588
mugzilla is offline
Old December 7th, 2009, 12:32 AM
is Fast Enough ...
mugzilla's Avatar
Yes but the weight that is transferred will push down with more force ...
As long as they are already loaded do a couple baseline runs with them on ...
mugzilla is offline
Old December 7th, 2009, 10:56 AM
I like station wagon springs !!!!!
oldcutlass is online now
Old December 7th, 2009, 11:06 AM
Trying to remember member
wmachine's Avatar
More than 2"
wmachine is offline
Old December 7th, 2009, 01:38 PM
ctrain22's Avatar
Originally Posted by wmachine
More than 2"
Now that's what I'm talking about. That black 442 sits perfectly. A little higher than I want, but it looks great. I want mine to be level, but just a little higher than stock.
ctrain22 is offline
Old December 14th, 2009, 08:07 PM
ctrain22's Avatar
Well, I installed a set of stock replacement hd springs in the rear, Moog #5409. It did the job I was looking for. Raied the rear about 2 inches. I guess the old springs were just weak. Now the fronts, although now that the rear is level, I might leave the fronts alone.
ctrain22 is offline
Old December 16th, 2009, 03:01 PM
before....
after....
I went a little overboard, but Now I can run 30x9" slicks and more gear if I want. Instead of my usual 27x8's
esisson
November 17th, 2021 05:40 PM
dancutlass
May 26th, 2012 06:00 PM
plee3 64Olds
March 29th, 2011 09:20 AM
NewOldsGuy
January 3rd, 2011 07:44 PM
oldsdroptop
April 18th, 2009 07:06 PM
Quick Reply: did you raise your olds???
