Aluminum heads inake
Old November 5th, 2007, 12:49 PM
ratsglass29
Guest
Posts: n/a
got aluminum heads with torker intake on the 455
Question is what needs to be done to the hood to use the OAI air cleaner setup
Rick
Old November 5th, 2007, 07:59 PM
Rick
Throw it away and get a different hood. The Torker does not work with the OAI hood. You can get a repro air cleaner adapter and cut it up to fit, but there's nothing you can do to the hood.
joe_padavano is online now
Old November 5th, 2007, 08:11 PM
2blu442's Avatar
Hi Rick
I don't think its huge on performance, but I've been told the older O4B aluminum intake will fit under an OAI air cleaner/hood setup. That's against factory cast iron heads, I don't think the aluminum heads would be any different but I don't know for sure. If you have factory OAI parts I wouldn't do anything to modify them, they're too rare and worth to much $$. Joe did mention the repo ring that doesn't have a flapper door in it, just the outer ring with the foam seal. That will shorten it some but I don't know if that's enough to use the torquer. John
2blu442 is offline
Old November 6th, 2007, 05:01 AM
Past Administrator
Oldsguy's Avatar
I ran an O4B on the 455 in my Delta, I think it was the the same height as stock.
Oldsguy is offline
Old November 6th, 2007, 02:24 PM
It's not, but it DOES clear the OAI hood and air cleaner adapter. The foam gets crushed a little more. Note that the O4B comes in two flavors, square bore and spread bore bolt pattern.
tocicar8825
September 21st, 2021 07:10 AM
import extermination
July 12th, 2015 08:30 PM
Octania
January 24th, 2015 09:28 AM
shermanator
February 27th, 2010 01:36 PM
Quick Reply: Aluminum heads inake
