442 stands for ?
Old April 23rd, 2014, 07:17 PM
knighthawk's Avatar
Location: from Wisc, then Texas, then Kansas, now back to Texas,
442 stands for ?
age old question ...what does the 442 stand for / I always thought it was for 4bl , 4 speed , dual exh. I was told today, it does NOT mean 4 speed . Says it was originally foe 64?(?) 4 door Police cars ????????
knighthawk is offline
Old April 23rd, 2014, 07:26 PM
2blu442's Avatar
Nope, you got bad info today. You were right the first time! In 1964 the only way you could get the car was with a 330 4bbl engine, 4 speed transmission, and dual exhaust. That gave it the name. From 1965 forward you could get an automatic transmission if you wanted, but the 442 name still applied.
John
2blu442 is offline
Old April 23rd, 2014, 07:42 PM
Justin
oldstata's Avatar
It really depends on the year it verys between years
I don't know all the diffrent meanings
oldstata is offline
Old April 23rd, 2014, 07:45 PM
66400's Avatar
And in '65-'69 it became 400 cid 4bl, dual exhaust although the 66 TriCarb didn't quite fit the formula.
Henry
66400 is offline
It doesn't really mean anything.
As John said, in '64 it had a meaning in the marketing literature.
After that, the specifications of the car no longer corresponded to the stated meaning, so you could make up anything you wanted, but the factory never said it meant anything after '64.
MDchanic is offline
Old April 23rd, 2014, 08:21 PM
Kyle's 77 Cutlass's Avatar
You mean four hundred and forty two? lol Kidding
Kyle's 77 Cutlass is offline
Old April 23rd, 2014, 08:30 PM
69ishHoliday's Avatar
First generation Z28 Camaro's were all four speeds, the stripes were optional, but real first gen Z28's all had a 302 engine and all were four speeds. The first Z28 available with an automatic was in the 70 1/2 where you could choose either. As the muscle was soon to depart the muscle cars.
69ishHoliday is offline
Old April 23rd, 2014, 09:15 PM
The engine for the '64 was borrowed from their Police package (remember, they were trying to quickly respond to the GTO), there were reportedly ten 4dr '64 442's built.
1969w3155 is offline
Old April 23rd, 2014, 11:29 PM
Diego's Avatar
Two points:
1. In 1964, the 4-4-2 meant 4-barrel, 4-speed, 2-exhaust.
But there is meaning after that, as in 1965 it meant 4-hundred cid, 4bbl. carb, 2-exhaust.
2. Stripes were standard on the Camaro Z/28. It was the only Camaro to have "band-aid" stripes aside of the '69 pace car; otherwise, the SS shouldn't have those stripes.
Diego is offline
Old April 24th, 2014, 12:17 AM
nsnarsk65cutlass's Avatar
What does the camaro have to do with the ops question?
nsnarsk65cutlass is offline
Old April 24th, 2014, 06:12 AM
Olds Wagonmaster
Arrowstorm's Avatar
Varies by year. I've learned that by 72, the 442 was nothing more than an appearance and handling package.
Originally, though, it meant 4bbl, 4 sp, 2 exhaust.
Arrowstorm is offline
Old April 24th, 2014, 06:55 AM
Beer Connoisseur
70cutty's Avatar
I thought it was the cubic inches.
70cutty is offline
Old April 24th, 2014, 08:09 AM
One thing is certain, there is a correct way to pronounce it:
1 (Redneck Style): "Forrrrrr Forrrrrteeeee TOOO"
2 (Hood Style): "Fow Fow Too"
3 (Correct Style): "Four Four Two"
All it was was a marketing technique. Successful one, as I think people talk it up
more than they talk about the Gran Turismo Omologato, which is Grand Tourer Homologated, for those that don't speak Italian.
Koda is offline
Old April 24th, 2014, 08:24 AM
66400's Avatar
Number 4
Don't forget immigrants, took a while to teach my wife (Vietnamese) it was not four hundred and fourtytwo but four four two! And my Chevelles were not SS three hundred and ninetysixes.
Henry
66400 is offline
Old April 24th, 2014, 08:55 AM
Trying to remember member
wmachine's Avatar
Sad to see how we've lost our history here. All of these posts and not the whole story. So here it is again (as this has been answered in this forum before):
In 1964, Olds defined 442 as "4-bbl carb, 4 on-the-floor, Dual Exhausts"
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
In 1965, with the auto trans available, Olds changed it to "400-cubic-inch V8, 4 Barrel Carb, Twin Pipes"
After '65, Old did not give any definition to the 442 numbers.
That's all there was.
wmachine is offline
Old April 24th, 2014, 09:11 AM
Octania's Avatar
What's it mean?
It means this here ain't just no F85, Cutlass or even Cutlass Supreme. It's got something SPECIAL.
Exactly what that special part is, varied from year to year.
But, it makes the owner feel good, folks discuss it, and the other driver intimidated.
Task accomplished, marketing.
Octania is offline
Old April 24th, 2014, 10:34 AM
And then there's the folks at car shows that think if it has an automatic, it can't be a 442.
Old April 24th, 2014, 08:28 PM
There's only one solution for that: RAUNCHY POWER BURNOUT while leaving.
Koda is offline
Old April 25th, 2014, 04:26 AM
Old School Olds
tru-blue 442's Avatar
How about the quad 4 442?
4 cyl. 4 speed, 2 buckets?
tru-blue 442 is offline
Old April 25th, 2014, 04:56 AM
oldsmobilty's Avatar
One example I found on Olds Faq:
Definition of 4-4-2 from the Oldsmobile Factory Literature:
1964 (Original meaning)
4: Four Barrel Carburetion
4: Four On the Floor
2: Dual Exhausts
1965 (First year of automatic transmission option on 442)
4: 400 Cubic Inch Displacement
2: Dual Exhausts
1985 to 1987 (Last of RWD 442s)
4: Four speed automatic
4: Four barrel carburetor
2: Dual exhaust
1990 and 1991 (FWD 442)
4: Four cylinders
4: Four valves
2: Two camshafts
oldsmobilty is offline
Old April 25th, 2014, 05:04 AM
wmachine's Avatar
If you really want to go there, the "Quad 4" is "4-valve, 4-cyl", and it is a 5-spd. So I think it would have been more appropriately "4-valve, 4-cyl, dual exhaust"
wmachine is offline
Old April 25th, 2014, 05:09 AM
wmachine's Avatar
2: Dual exhaust
4: Four cylinders
4: Four valves
2: Two camshafts
Though these references were made, I don't believe they were offered as *definitions* of the 442 numbers for those years.
wmachine is offline
Old April 25th, 2014, 05:40 AM
DENT's Avatar
Just the other day a co worker insisted that 442 meant 4 barrel 4 speed 2 door , this is an AMC expert .
DENT is offline
Old April 25th, 2014, 05:41 AM
Kurt I agree, no contest here. Just a reference and definition of 442 as you stated.
Old April 25th, 2014, 06:21 AM
wmachine's Avatar
Seems someone always has to be wrong, and it looks like he volunteered.
wmachine is offline
Old April 25th, 2014, 09:16 AM
knighthawk's Avatar
real interesting , thanks guys !
Old April 25th, 2014, 10:25 AM
Old School Olds
Ha ha! I knew you would chime in Kurt.
Just checking. Happy Friday everyone.
Old April 25th, 2014, 10:54 AM
Olds Wagonmaster
Arrowstorm's Avatar
After this thread, I am DEFINITELY getting 442 emblems for my Vista Cruiser.
Old June 13th, 2014, 01:07 PM
JohnnyBs68S's Avatar
I used to claim i had a 1/2 of a 442 = "2-2-1"
2-bbl carb
2-speed auto
1-single exhaust
JohnnyBs68S is offline
Old June 17th, 2014, 12:25 PM
tva442's Avatar
I still claim my '69 3 speed manual is a 4-3-2
tva442 is offline
Old June 26th, 2014, 12:31 PM
  #31
cecilsclassics's Avatar
442 - 4 cylinder 4-valves per cylinder 2 cams!!! LOL!!!
cecilsclassics is offline
Old June 26th, 2014, 02:21 PM
  #32
Mr. Johnson
rjohnson442's Avatar
4 tail lights 4 you 2 see disappear works on a 72 at least. or nowadays 44 2Much.
rjohnson442 is offline
Old June 26th, 2014, 03:50 PM
  #33
Sampson's Avatar
Amazing how many people come up to me and ask if I have a 442 cu in engine. I just smile and say yep!
Same when I drove a Charger. Most people would look and say is that there one of them hemi's? Yep!
If they cannot look and at least get in the ballpark it's no use trying to explain
Sampson is offline
Old June 26th, 2014, 04:32 PM
  #34
MOTORHEAD
11971four4two's Avatar
Hank who lives a couples houses down the block told me it was the size engine that i had in my nova.
1971 4bbl TH400 dual exhaust
11971four4two is offline
Old August 17th, 2019, 12:12 PM
  #35
Inline's Avatar
4 tail-lights 4 you 2 see?
Inline is offline
Old August 17th, 2019, 09:52 PM
  #36
Daiv8or's Avatar
Add two zeros to the end and that's what you're supposed to expect at a fancy auction. (Adjust your actual reality accordingly) That's pretty much what 442 means today. For a W- anything... add another zero I guess.
Daiv8or is offline
Old August 20th, 2019, 06:30 PM
  #37
matt69olds is offline
Old August 20th, 2019, 06:32 PM
  #38
Old August 20th, 2019, 06:35 PM
  #39
Simple arithmetic:442= a perfect 10!
65B01Delta
July 1st, 2018 02:45 PM
HonestDave
November 16th, 2014 05:00 PM
mgreen0104
August 9th, 2013 11:28 AM
White_Knuckles
October 17th, 2012 01:39 AM
Quick Reply: 442 stands for ?
