1967 Climatic Combustion Control
Old April 7th, 2007, 07:23 AM
2blu442's Avatar
Does anyone know if this setup was used on 442's?
2blu442 is offline
Old April 5th, 2010, 09:08 PM
TPKRUZR's Avatar
Hey 2blu442,
Do you have that car?
Thanks, TPKRUZR
TPKRUZR is offline
Old April 5th, 2010, 09:39 PM
2blu442's Avatar
Sorry, it had rust and had been sitting for about 15 years before I got it. I dismantled it. But looking back, it had some rare options on it and I wish I had been able to save it. I do have a 1966 Toro parts car that's pretty complete, plus odds and ends from a couple more 1966 & 67's. John
2blu442 is offline
Old April 6th, 2010, 02:46 AM
Registered
Bluevista's Avatar
Oldsmobility has an old Motor Trend article that says the K50 Engine Air Induction System/Climatic Combustion Control option was available on all two and four barrel engines, if it's to be believed.
It came standard with the Turnpike Cruiser option but that was only available on the Cutlass.
http://www.oldsmobility.com/mtrtrnd_feb67.htm
Bluevista is offline
Old April 6th, 2010, 05:24 AM
Shoveling Snow
Hairy Olds's Avatar
The K-50 air cleaner was used in 1967 only engines across the board except 6 cyl. The main difference is going to be the exhaust heat tube and the flexible tube going to the housing. Some were flexible tubing such as what you have on your Toro and some looked like radiator hose.
Hairy Olds is online now
Old April 6th, 2010, 09:08 AM
TPKRUZR's Avatar
Hey 2blu442,
Years ago I had a 1967 442 with the K-50 option. Now I have a 1967 Turnpike Cruiser that I would like to put a four barrel on but keep the stock look. So what I am after is the air cleaner, carb and intake. Do you have any of the parts?
Also there is a guy that is making a overlay/decal for the lid but I can't find the link now, do you have it?
Thanks, TPKRUZR
TPKRUZR is offline
Old April 6th, 2010, 02:03 PM
Shoveling Snow
Hairy Olds's Avatar
https://classicoldsmobile.com/forums...aint-mask.html
Old April 6th, 2010, 02:34 PM
Lt. Buzzkill (ret.)
copper128's Avatar
My '67 442 shows the K50 option on the window sticker. It had a chrome snorkel air cleaner on it when I bought it though.
copper128 is offline
Old May 3rd, 2010, 02:50 PM
Benny K's Avatar
The 1967 442 I unfortunately sold a few years ago (my biggest mistake in life so far) had it too..it was a true 442 with some very odd options..
Front Disc Brakes
Power Windows
Power Antenna
and bench seat with column shifter..
here's a pic of the engine compartement...it was all stock...untouched engine. When I got it in 2001 it even had it's original spark plug wires (date coded 1966) on it...I still have them...
Benny K is offline
Old May 3rd, 2010, 03:37 PM
todd66442's Avatar
mighty clean original for sure. It's to bad that Olds didn't chrome the thing.
todd66442 is offline
Old September 29th, 2016, 07:43 PM
MudEye's Avatar
Just found this thread. My 67 Cutlass Supreme has this breather and gets so many positive comments. Funny thing though...Everyone ask Me " What is Climatic Combustion Control " And I always say " Good question" ...HeHe
I have no idea what it means.....Does anyone?......
MudEye is offline
Old September 29th, 2016, 09:19 PM
It is a performance enhancer in terms of bringing the car up to temp faster and regulating the intake air temp. There is a clamp on shroud around your right exhaust pipe with holes and a hose going to the air cleaner and that is the hot air source. The right inlet on the air cleaner is the underhood air source. The left inlet is an additional underhood air source for max performance.
There are two vacuum motors, the right side one is thermostat controlled via a bimetallic thermostat inside the air cleaner. If the air inside the cleaner is below a set range of 90 to 120 deg F, the air cleaner pulls air from the hot air source. If above, the vacuum is dumped to the motor, and the spring pulls the right side inlet door open and you pull in underhood air from the inlet.
The left motor and inlet does nothing on 2 barrel 330s. If you have a bigger engine, WOT and loss of vacuum will ALSO pull the left door open, and you will then be sucking air down both inlets. Once you let off, the left door will close, and you will be back to whatever the right side is doing based on your air cleaner temp.
With the engine off, you lose all vacuum, and it should haul both doors open, but that may only be if the engine is hot.
It's a predecessor to the chimneys and heat risers seen on the 70s cars.
67 had a buck ton of air cleaners. A normal 2 barrel, a normal 4 barrel, this thing, 3 442 only ones, and a OAI. Seven I think.
Koda is online now
Old September 29th, 2016, 09:21 PM
Edit, the one on the right may not be a vacuum motor, may just be spring thermostat controlled.
Koda is online now
Old September 30th, 2016, 03:36 AM
Oldsdruid
rocketraider's Avatar
That's the best diagram of how 1967 CCC works I've seen. Where'd you find it?
Add in each carline had its own version of the CCC aircleaner, and things really get interesting.
rocketraider is online now
Old September 30th, 2016, 08:50 AM
Google, oddly enough. I think it's on oldsmobility.
Koda is online now
Old September 30th, 2016, 05:03 PM
MudEye's Avatar
Do these breathers break down mechanically ( springs,vacuum,sensor,etc.? ) and will they effect the way the carb performs? ( feeds the carb with more air for performance....) ...Curious.. Also is there a original decal that can be bought for ( Combustion Control ) or an a pliable template of sorts..( not the computer generated one posted for a 100.00 )
MudEye is offline
Old September 30th, 2016, 07:29 PM
66-3X2 442's Avatar
I have a 2V version if anybody needs it. The decal pan is missing but otherwise in great shape.
66-3X2 442 is online now
Old October 1st, 2016, 04:37 AM
rcktdoc's Avatar
I have the correct 4 barrel air cleaner.
rcktdoc is offline
Old October 2nd, 2016, 07:07 PM
MudEye's Avatar
fhttp://www.rubbertherightway.com/1967-oldsmobile-restoration-parts-climatic-66355-prd1.htmor Found this link and what appears to be an exact replication decal . I already ordered and will keep you posted as how it turns out....But for 16.00 I may order a 2nd in case I mess it up....
MudEye is offline
Old October 3rd, 2016, 04:45 AM
Shoveling Snow
Hairy Olds's Avatar
There is a difference in quality and you will find this out. All of my customers understand quality vs price. My products are not for everybody.
Old October 3rd, 2016, 08:40 AM
I saw a valve cover sticker for $1200 somewhere. Might have been here or on ebay.
Koda is online now
Old October 3rd, 2016, 04:38 PM
Shoveling Snow
Hairy Olds's Avatar
That was mine and it sold for a little north of that.
Old October 3rd, 2016, 04:44 PM
MudEye's Avatar
Climatic Combustion Control" Air Cleaner Decal
1967 Oldsmobile Restoration Parts
1967 as required
| 1 Reviews
Tweet This share on FaceBook
"Climatic Combustion Control" air cleaner decal. Replaces original GM part #357396. Add that final touch to your restoration. Top quality, licensed GM product. MADE IN THE USA. PART #: DO0557
Price: $16.20
http://www.rubbertherightway.com/#lo...r_id_61=61|172 All Decals available:Jetfire,ultra high compression,Super Rocket,Toronado,etc..
MudEye is offline
Old October 3rd, 2016, 05:19 PM
MudEye's Avatar
16 dollars and 20 cents
You be the judge ....I only want to save money..
MudEye is offline
Old October 3rd, 2016, 05:35 PM
MudEye's Avatar
Harry.. Are these low quality? Please tell Me because I just ordered them..
They appear original...
Thanks...
MudEye is offline
Old October 3rd, 2016, 05:37 PM
Shoveling Snow
Hairy Olds's Avatar
Then why spend the money in the first place.
Old October 3rd, 2016, 06:15 PM
MudEye's Avatar
I have no quarrel here...Just please let us all know whether or not this product is the same as yours...If not ..Great! Just please tell us if the parts number you sell is different than this one... If its something different then let us know the difference....( paste your part number ) I'm really not savvy on parts numbers.
But if 100.00 vs 16.20 is a big difference. And Please forgive Me if I seem to challenge You..It's no disrespect. Just clarification...We all want to save money on our beloved classic cars...And we all want know who's ripping us off...and who's not!... Who's loyal to ClassicOldsmobile...people....
Thanks!!!
MudEye is offline
Old October 3rd, 2016, 09:58 PM
66-3X2 442's Avatar
Thanks!!!
There is a difference between a stencil and a decal. Good luck getting the decal to lay flat on that curved surface.
Old October 4th, 2016, 06:57 PM
Shoveling Snow
Hairy Olds's Avatar
What the man from bama said!
mid60soldsfan
October 21st, 2013 10:10 AM
jamac
June 15th, 2013 11:50 AM
jeffreyalman
June 16th, 2010 04:07 AM
henryford
February 1st, 2010 09:05 PM
NoVa_144
October 27th, 2009 08:12 AM
Quick Reply: 1967 Climatic Combustion Control
