1965 A-Body Rear Seat Belts
Old November 22nd, 2009, 12:13 PM
2blu442's Avatar
Hi all
I recently picked up a 1965 F85 that had been stripped down for a budget 1/4 mile drag car. Major rust around the front and back windshields and a badly rotted floor pan is what caused the previous owner to cut it up. I'm evaluating what parts I want to swap over to my 1965 442 project car. I know there's no rear seat belts in my 442 and this F85 has some heavy duty loops behind where the rear seat had been. I'm hoping some of you 1965 guys can tell me if these were factory or aftermarket items. I'm not sure how the seat belts would have been attached, but the locations seem logical and it looks like they've been there a long time. Here's a few pictures, any thoughts??? The outboard ones go into the wheelwells.
2blu442 is offline
Old November 22nd, 2009, 12:28 PM
Those loops are aftermarket and typically come with racing seatbelt sets. Those are not the factory locations for belt attachment anyway, since you'd be hard pressed to use them with the rear seat in place.
joe_padavano is offline
Old November 22nd, 2009, 12:35 PM
Old November 22nd, 2009, 12:43 PM
2blu442's Avatar
Thanks Joe! OK, one less thing on my list to keep!
2blu442 is offline
Old November 22nd, 2009, 01:21 PM
TK-65's Avatar
The flat areas right next to those loops are where the belts would attach.
TK-65 is offline
Old November 22nd, 2009, 02:11 PM
2blu442's Avatar
Thank you for the picture TK-65, as I do want to install seat belts in my project car. John
2blu442 is offline
Old November 22nd, 2009, 02:16 PM
I would suggest that instead of using fender washers, get the thick oval plates that the factory used. These are available from numerous sources.
Old November 22nd, 2009, 06:57 PM
TK-65's Avatar
Again those washers are what the factory used. These belts/washers/bolts came out of an original car at the same time. And notice the round washers, which have a part number on them, fit the round spot on the floor. You may argue that the bigger plates are safer but this is what GM used in 65.
TK-65 is offline
Old November 23rd, 2009, 01:18 AM
German442's Avatar
@ 2blu442: I'd believe the above. This is RamZ on www.ultra-high-compression.com. I'd consider him & 442Bro THE authorities on 64/65 Cutlass/442. Between them, they've got the answer to almost any question on these cars. His car is also the only '65 442 to be covered in a national Classic car mag!
Ralph
German442 is offline
jcmoretti
July 11th, 2018 03:07 PM
DaveD65
June 23rd, 2014 08:42 PM
69442murph
January 19th, 2013 11:55 AM
sx455raidercelticfan
December 26th, 2010 04:13 PM
December 21st, 2010 08:59 PM
Quick Reply: 1965 A-Body Rear Seat Belts
