14 x 6 R coded rim Manufactures?
Old December 18th, 2015, 02:36 PM
jim larson's Avatar
Wondering about the R coded drum rim from 65-68 on the 442. Were there 3 manufactures, Norris Technologies, Kelsey Hayes, and Motor Wheel Corp?
If so, was the center section and outer rim design different between different manufactures? Thinking that NT and Kelsey Hayes use the same design for both the center section and outer rim design except for different stampings. And that Motor Wheel used a slightly different center section design and also a different outer rim design.
What about the same rim for the GTO, Chevelle SS, and Buick? Thinking that they used the same rim except for the Code. GTO and Chevelle SS sharing the same code, unsure about the Buick code.
jim larson is offline
jim larson
April 1st, 2016 02:13 PM
fjross
October 14th, 2010 02:15 PM
monzaz
Drivetrain/Differentials
January 28th, 2010 12:13 PM
oldzy
September 10th, 2009 05:23 AM
1BAD68"S"
February 15th, 2007 07:38 PM
Quick Reply: 14 x 6 R coded rim Manufactures?
