Click Here
SSII Center Cap Bolts
Old Apr 3, 2013 | 08:33 PM
4WDlifeform's Avatar
Work hard, play hard.
Sorry if this is a re-post, but I searched and searched...
What is the correct hardware for bolting the center caps to the wheel on the SSII? I bought a set of SSII, with only 2 center caps and no hardware. I have now bought a set of new caps, but doesn't look like hardware is supplied. I'd like to hit up the hardware store on my commute tomorrow.
I found an image on the web, but it could not find the article it was posted?? Here is what I found, and I can probably match it up with a center cap and this image at the store (if it is correct).
http://i38.tinypic.com/de0h9w.jpg
Thanks in advance!
Old Apr 4, 2013 | 10:39 AM
Thanks in advance!
That's the correct bolt, but it's a special bolt. Good luck matching that up at a hardware store.
Old Apr 4, 2013 | 11:43 AM
Oh fun... Is there a specification to that bolt size? Thread per inch? Nominal diameter?
From the image, I am judging it is 1/4" with 7tpi... I found this:
http://www.fastenal.com/web/products...Id=&rfqLineId=
Their image doesn't match the description, and info does not give a TPI count...
EDIT - 14tpi, not 7!
Old Apr 4, 2013 | 12:04 PM
Here you go. 18.00 for all 20
SSII Center Cap bolts
Old Apr 4, 2013 | 07:17 PM
Lady72nRob71's Avatar
I got my bolts at home-creepo - a couple bucks for 50 of them.
They fit fine and looked just like my originals, except for the addition of a slot in the hex head, which of course cannot be seen...
Old Apr 4, 2013 | 08:41 PM
The caps I ordered in must have been repops... they took a metric M6 thread.. got them installed today. Thanks for the help!
Old Apr 4, 2013 | 09:08 PM
stevengerard's Avatar
I'd put a dab of silicone or thread lock on the screw as well just to make sure they don't come loose. Hate to see new center-caps come off.
sixty9olds
Nov 27, 2018 06:54 AM
nolabigdawg
Oct 25, 2014 11:50 AM
4WDlifeform
Wheels and Tires
Apr 20, 2013 11:14 AM
ROBZ442
Mar 16, 2013 02:34 PM
Alex72cutty
Jul 8, 2012 11:07 AM
