Will a different size tire fit on my rim ?
I was wondering if lets say a P255 60 16 will fit on a 15 rim ? I'm having an awful time trying to find some tires for my new used 15 " rims I just put on my CS . My rims are SS2 15X7 . I see tons of 16 " rims on for sale on Craigslist , but not many 15's . If anyone has any used tires close to me that they are looking to get rid of let me know . thanks Bryan
BTW... I guess I'm looking for 2) P255-60-15 for the back , and 2) P225-60-15 for the front . or whatever that doesn't rub on the fender when I turn sharp .
215/60/15 or 225/60/15 are good choices for your car. Why are you looking for 255 or wider?
Lesson 2 on tires. The last number is your wheel size - always. So you need to have 15" tires, not 16, not 14. They just won't fit. It's like trying to put on size 32 jeans when your waste is 36. or Size 36 jeans when your waste is 32 - you get the idea.
The width to aspect ratio needs to equal the diameter of your original wheel/tire combination unless you plan to change out the speedo gear.
Have you looked on CL or Kijiji? I just looked and found some right away. Here's an example http://ontario.kijiji.ca/c-cars-vehi...AdIdZ458096153
I like the wide look in the back , and I was planning on keeping the current tires I have on the front ( P225-75-15 ) , so this works out almost perfect .... eventually I will figure out what I want to do when I get this car painted .... Whenever that will be .
, I feel like I could go off roading .
That's an excellent argument, I'll go ahead and keep endangering all the other people in traffic needlessly, then.
Facetiousness aside, I think it's a valid question to get that aspect of the equation as well.
I wont be exceeding speeds of 40MPH anyhow . I'll be lucky to put 500 miles a year on this car , probably not even half that . I need to do some work on the motor before it blows up .
omg I didn't think of that . Well , I have no choice now unless I get some used front tires too . Three of the four tires I had on the car were REALLY bad , so I can't put them back on . I guess I don't always think things through .
That's not a bad deal . I forgot that you can ship things via bus . I checked some tire sites , and the minimun rim size range for a 255-60-15 is 7" according to them.
plee3 64Olds
Wheels and Tires
Feb 27, 2012 01:18 PM
bigjaythe1st
Wheels and Tires
Feb 22, 2012 01:37 PM
