VC gas tanks
Old Sep 30, 2011 | 07:26 PM
Hal's Avatar
Hal
VC gas tanks
Anyone tried using an El Camino tank in their wagon. On paper it looks as though it should work. Just wondering...
Old Oct 17, 2011 | 07:51 AM
WoofWagon's Avatar
The elky tank is on the side of the car like a Vista?
Old Oct 17, 2011 | 11:22 AM
Hal's Avatar
Hal
tank
They both are under the back. I got the El Camino tank and installed it. The neck comes out further forward (about 6") and higher up on the side. I hole sawed the frame and added a gusset to the inside frame rail. I got the Spectra tank with pump/sender in tank. I'm doing an LS conversion and it should work fine. Hal
Old Oct 17, 2011 | 11:58 AM
Lady72nRob71's Avatar
What year Vista? Late 60s and early 70s models had them on the side...
Old Oct 17, 2011 | 12:07 PM
WoofWagon's Avatar
I need a sending unit for my '70 Vista.
Old Oct 17, 2011 | 12:50 PM
DJS70cutlass's Avatar
^ a perfectly executed thread jack
Old Oct 17, 2011 | 12:55 PM
WoofWagon's Avatar
Sorry, I cornfused this with another thread I posted on. I would like to find a replacement tank if the situation warrants though.
Old Oct 17, 2011 | 10:03 PM
Hal's Avatar
Hal
Tank
I have a 1965 VC. It looks like 64-67 used the same tank. The El Camino tank is the same size as the VC, there even is a flat place for the fuel neck where it 'should' be. Was able to reuse the straps and the tank fit perfectly except for the neck location. I was able to cut a piece out of the fill tube and reweld it to fit. Not a real big job for sure. BTW, the fuel gauge works great-had a bad sender in the old tank. Hal
Del70
Jul 17, 2014 05:43 PM
mrwiuff
Drivetrain/Differentials
Jul 27, 2012 09:23 AM
Wyze
Mar 8, 2010 06:07 PM
ent72olds
Sep 16, 2009 04:02 PM
mryoung4815
May 28, 2009 07:53 PM
