Damn Kids
Old Oct 10, 2010 | 03:40 PM
The Tin Man's Avatar
The Tin Man
Damn Kids
Hey my kid draged home a custom cruiser today. So I kicked him out of the house No wagons here I said.
Ok I was just kidding I did not kick him out.
See this is where I ask you wagon guys how too ???? (please) Ther is rust uder the wood grain. yes its true I know that has not happened to anyone here or the world its just my luck right. Well if it has happened to someone you know how do you get all the contact paper off the sides. (opps! I mean wood grain) Ther has to be a trick to it come wagon guys give me some help. ( and some poop ) Thanks for your help as you can see by this ad I need it. (oh its a 87 I know no that old but it is older then him LOL) Tin man
Old Oct 10, 2010 | 03:57 PM
ent72olds's Avatar
Registered Luser
Well, being you asked so nicely, the best and quickest way is to light the car on fire.....in a couple of mins, it should be completely off!
Old Oct 10, 2010 | 04:02 PM
ent72olds's Avatar
Registered Luser
OK, on a more serious note, what worked for me was a heat gun....once you get a corner started, heat a few inches ahead and pull gently, trying to keep in one piece! A plastic scraper helps behind it while you're at it also! Really, there is no easy way!
Old Oct 11, 2010 | 03:02 AM
Bluevista's Avatar
Registered
Wallpaper Wagon
It's not contact paper!
It's cast woodgrain vinyl, contact paper is for shelves.
Like Erik said, use a heat gun and a lot of patience.
You may pull some of the paint off with the woodgrain too.
Old Oct 11, 2010 | 04:54 AM
The Tin Man
Ok I will try the old heat gun trick. Thanks for your thoughts. Lighting it on fire is not a bad Idea but the kid would be upset and that would make mama upset. I don't want to do that. Thanks Tin man
Old Oct 11, 2010 | 07:17 AM
Be aware that the woodgrain appliqué is NOT contact paper. It is a much thicker vinyl material with a clear cover and made from UV resistant materials. Once you remove it, you cannot replace it with shelf paper. The correct material is not cheap, either.
gearheads78
May 9, 2012 10:36 AM
1956OldsDarrin
Feb 9, 2011 02:38 AM
American Lead
Apr 20, 2009 12:47 PM
mikeb
Aurora
Feb 15, 2009 02:55 PM
68Tom
Nov 29, 2008 03:21 PM
