Stock Tranny
Old Mar 1, 2004 | 10:04 AM
Tweety's Avatar
Post
What was the stock tranny in a 1972 Olds F-85/Cutlass? I am looking to upgrade the motor, and I am not sure if the TH-350 is going to be able to take what I throw at her.
Old Mar 4, 2004 | 06:19 AM
jdorour's Avatar
Post
Generally the TH350 was used with the 6cyl and all 350cid V8’s and the TH400 was used with the 455cid V8. The transmission from the 6cyl is different than the trans used with the V8.
There are different transmission codes used with different engines and heavy-duty options.
The codes don’t really matter if you are not doing a restoration. You will need to be aware of a couple of things:
There are two different bell housings for all GM transmissions Chevy and BOPC.
There are short and long tail shaft THM400
In the late 70’s early 80’s GM built a trans type THM 375B this looks just like a 400 but is a lighter duty unit. Most of the time it was used on the 403 and big cars with the 350.
Lastly 64, 65, 66 and 67 BOPC THM400’s are Switch Pitch units and will require some additional wiring to work the switch pitch converter
Old Apr 28, 2005 | 04:04 AM
eichh2000's Avatar
Post
Its all in how they are built I ran a 350 for years with 500 hp on it and I am currently running 800 horse on my powerglide. Just as long as they have the right clutches you shouldnt have a problem.
Old Apr 28, 2005 | 06:23 AM
yogi442's Avatar
Post
one other note, Olds came with TH400 on 350V8's with factory tow packages. As with my 76 Cutlass. Otherwise TH350 with 350ci V8.
odddoylerules
Transmission
24
Jan 22, 2014 06:35 AM
delta254
Dec 3, 2012 08:37 AM
ijasond
Transmission
Aug 5, 2008 07:05 AM
<jdhideaway@aol.com>
Brakes/Hydraulic Systems
Mar 31, 2005 08:15 PM
JP63
Transmission
May 19, 2003 02:05 PM
