Air fuel problems
Old Dec 16, 2008 | 04:46 AM
Bunser's Avatar
Air fuel problems
I have a 70 W31 engine with the original quadrajet carb.When dyno tested the A/F readings were ranging from 7 to 9. Just a bit rich.Any suggestions (except from Norm) would be appreciated.Thanks.
Old Dec 16, 2008 | 06:35 AM
cutlassefi's Avatar
Air/Fuel
Gotta check a bunch of stuff, the bowl plugs, they normally leak, fuel pressure, yes the primaries do have metering rods, are they sticking etc. Needle and seat, good condition, set right? If possible try another carb on it. Or you maybe have to send it out to a more competent rebuilder. Good luck!
Old Dec 16, 2008 | 07:37 AM
rocketraider's Avatar
Oldsdruid
W31 shouldn't have primary metering rods, unless everything the factory put out about them is a lie...
Are these A/F readings at WOT or thruout pull range?
Old Dec 16, 2008 | 10:18 AM
cutlassefi's Avatar
Air/Fuel
Sorry guys, every Quadrajet I've ever seen had primary metering rods. My mistake.
Old Dec 18, 2008 | 04:12 AM
Bunser's Avatar
It probably doesn't interest too many,but, on runs three days apart, the following results were obtained.On the first day the readings ranged from 11.4 to 14.0. Three days later (same secondary rods and same hanger) it ranged 7.8 to 9.8 with rpm range from 3000 t0 5500.
His explanation was different atmospheric pressure or air density or maybe tooth fairy dust. I'have to believe that his test instrumentation needs calibrating/overhauling! Any comments welcome.
Old Dec 18, 2008 | 08:47 AM
cutlassefi's Avatar
Air/Fuel
I agree. At around 8.0 to 1 air/fuel I'm pretty sure it would have been belching black smoke. May want to try someone else, at the very least different equipment.
chasman414
Jun 25, 2020 07:05 AM
KQQLCAT
Sep 20, 2015 05:49 PM
1965cutlassragtop
Jul 15, 2012 06:26 PM
2blu442
May 1, 2011 07:29 AM
dandl1862
Aug 14, 2006 03:29 PM
