No Vacuam
Old Nov 15, 2008 | 10:29 PM
woodie582's Avatar
No Vacuam
Hi, 71 350 4 spd. I had my Qjet rebuilt and put it back atop an rpm performer, it run but has problems. Irrateic idle and blubbering. Long story short on my throttle plate I have PCV vacuum but no vacuum on the second smaller nozzle. I have the carb off and can see no reason why that 1 port would not be pulling vacuum.. Thoughts welcome.
Old Nov 16, 2008 | 03:39 PM
Oldsguy's Avatar
Past Administrator
Is it possible you used the wrong gasket? I know those kits have many "extra" gaskets and they all look very similar but they are different.
Old Nov 16, 2008 | 06:22 PM
88 coupe's Avatar
Junior Member
Originally Posted by woodie582
........ no vacuum on the second smaller nozzle ........
If it is the one for the vacuum advance, it is not supposed have vacuum when the throttle blades are closed.
Norm
Old Nov 16, 2008 | 09:54 PM
BILL DEMMER's Avatar
Just the facts...
the second nozzle you mention, is it to the right of the pcv nozzle(or port)?
if so, that is the canister purge port and it is a timed vacuum port. it will not have vacuum at curb idle speed. it will have vacuum after you open the throttle about 8 degrees.
bill
Old Nov 17, 2008 | 01:08 PM
woodie582's Avatar
Thanks all. I am using manifold vacuum for now. Dec 8th is set for dyno tuning.
NMcCarthy
Nov 11, 2014 10:46 AM
