Need help with my build.. What to do?
Old Nov 25, 2008 | 10:16 AM
  #41
Wireman134's Avatar
Originally Posted by J-(Chicago)
Good point. Something I didn't think about. Thanks.
With water it would be tough to see, maybe use a straight 50w... LOL
Old Nov 25, 2008 | 10:17 AM
  #42
J-(Chicago)'s Avatar
Seasoned beater pilot.
Originally Posted by 88 coupe
Many times, because of this myth, the pickup is placed too close to the bottom of the pan. First thing my machinist cautioned me about.
If they were a problem, it would have been addressed. Likely while they were involved with racing. Starting with the D heads, for instance?
Norm
I used a Melling M-22FHV pump.
However, I didn't use their bolt on pickup.
I wondered if their bolt on pickup would always be in a set position. How does Melling know what pan I'm going to be using? Answer: They dont.
I used the melling pump with the stock 455 pickup. This way I can position it wherever I want, and then tack weld it in place.
Some thought it was a clever idea, and others thought it was stupid.
Meh.
Old Nov 25, 2008 | 10:54 AM
  #43
Wireman134's Avatar
Here is a diagram of the oiling system fellas
http://s45.photobucket.com/albums/f9...lingsystem.jpg
Old Nov 25, 2008 | 03:56 PM
  #44
380 Racer's Avatar
The pickup tubes are designated by pan depth when ordering it. When we deepened a stock pan. We used a 2" dropped pickup tube. Had a 3/8 nut between it and the pan bottom. Welded the pan up with no problems. I have always used restrictors in the main saddles and restricted push rods, plus a HV pump.
Old Nov 26, 2008 | 12:27 AM
  #45
Learned something new today. Thanks Nick.
Old Nov 26, 2008 | 11:19 AM
  #46
380 Racer's Avatar
No problem.......your welcome!
Old Nov 26, 2008 | 05:37 PM
  #47
Warhead's Avatar
I am also a fan of restricting the cam bearings, but I will never run a push in restictor again due to the fact I had 1 drop down to behind the main bearing on a 350, even though it was loctited in. Nice oil blockage.
I always drill a new oil hole in the cam bearing at .080-.100 inch. These don't move.
I will always wonder why they sell cam bearings that have a .225 oiling hole, and the main bearing will be lucky to have half of the oiling hole line up, before I modify them.
Mondello restrictors are .080 for reference sake.
JMHO,
Jim in Phx
Old Nov 26, 2008 | 06:22 PM
  #48
The_Jeremiah's Avatar
I'd build up the 350 with the 5 heads, but that's just me.
I traded my 403 block and crank for a nice set of battery cables for my 350
lol nice. if i ever decide to sell my 350, you will be the first to know!
Old Nov 29, 2008 | 11:23 PM
  #49
74omega's Avatar
I am "74omega" NO SPACE
Man awesome info here. I will start the build at the beginning of the new year (after the holiday's of course).
Just for kicks here is the 403 as I bought it for $50 just as it looks in the pics. I think I got a good deal.
agreen316
Dec 21, 2013 06:27 AM
wildwillie1981
Apr 24, 2013 04:19 PM
Colpage1
Jul 5, 2012 03:20 PM
unrelatedbrothers
Jun 24, 2009 05:22 PM
69 442 protour
Dec 9, 2006 09:25 PM
