clutch fan swap?
I would go for it myself, I like mods that are easy to put back, It's not like a cam change or anything.
Make sure the spacer is the right size, it makes a big difference in cooling where the fan sits in relation to the shroud. The size and number of blades usage chart for different engines and body types is in the manual too.
Allan
Changeover cooling fan
You can probably get all the parts you need used for under 200 bucks. Been my experience that the fan shroud is usually the most expensive part. Fans, fan clutch, water pump I got some new some used for around 25 bucks each. My shroud is new and cost 90.00. The gaskets cost around 45.00 new for everything.
I'm doing this to my car, and there's absolutely no downside except it costs money for the other parts. Like Allan H says though, it's easy to put back to original if you want.
If you're going to do the clutch fan (which I would just on principle) you might want to look at putting in a HD water pump, and fan shroud to direct the cooling. The HD water pump will give you the proper spacing that you will need for your belt, but you will need a new pulley to fit it because it bolts in "backwards" compared to the original cooling fan you probably have.
