What year is my engine?!?
Old May 20, 2008 | 07:03 AM
UCF72Cutlass's Avatar
I have a 72 Cutlass with a 350 but the owner told me he believes it came out of a hurst oldsmobile. By the vin it should be a V8 350 with 2 bbl but its a 350 with 4bbl quadrajet Looks like oldsmobile didnt put 350s in till later in the 70s for hursts. How do i find out exactly what engine I have and i just ordered a 72 assembly manual. Will i run in to problems and differences when using the manual on my car?
Old May 20, 2008 | 07:57 AM
Redog's Avatar
There is a VIN plate on the left front side of the motor. It's around the number 1 spark plug.
The first number on this plate will be the last number of the year.
If it's a 395558 block it would be from 8=1968 to 6=1976
You shouldn't have any problems as long as it's around the same year
Old May 20, 2008 | 09:54 AM
Yeah, and every 327 Chevy is from a fuelie Vette...
Anyway, as noted above, the VIN derivative stamp on the front LH side of the motor will tell you the year. This is a nine character stamp. The second character is the year. 8 = 1968, 2 = 1972, etc. The assembly manual contains almost no data on the engine and your later 350 won't matter. Get a Chassis Service Manual for all the torque specs and rebuild info. For the most part, all 68-76 350s are the same as far as clearances and torques are concerned. The 77-up motors used windowed main webs with larger head bolts, so there will be some differences for those.
Old May 20, 2008 | 10:29 AM
When i buy parts what should i be buying for?
Old May 20, 2008 | 12:22 PM
i looked on my motor and could not find the 9 digit number.
Old May 20, 2008 | 02:18 PM
Jokers69's Avatar
Senior Moment
this isn't the tell all, but whats the big number, big single digit not long number, on the head
Old May 20, 2008 | 03:32 PM
all i really find is right behind the water pump i have 395558 with a big 2 at the end. Its engine is pretty much all painted red not sure if that helps or not.
Thanks for the help everyone
Old May 20, 2008 | 04:08 PM
The number behind the water pump is the casting number. The VIN derivative is below the no. 1 spark plug on the side of the block and is usually partly covered by the power steering pump bracket and a lot of grunge.
Old May 20, 2008 | 05:06 PM
i must be blind i cant see it
Old May 20, 2008 | 06:55 PM
1972 X code 442's Avatar
Hurst/Olds cars didn't come with 350 V-8's (W25) until 1974 MY. In MY 1975 a 350 V-8 (W25) was again offered and of course in MY 1979 it was the only engine.
Without knowing the engine unit number (on the oil fill tube) it's hard to tell, especially since the engine code i.d. sticker (also on the oil filler tube) usually comes off after a few years due to engine heat.
Old May 21, 2008 | 07:47 AM
See attached
File Type: pdf
Old May 21, 2008 | 10:05 AM
Redog's Avatar
You def have an Olds 350 from 68 to 76.
My bad, the first number in the engine VIN will be a 3, the 2nd number will be the last number of the year, The 3rd is a plant code. Mine is an "D" but I have no idea what plant that is
Old May 21, 2008 | 10:16 AM
D = Doraville, GA
Old May 21, 2008 | 11:36 AM
Redog's Avatar
^^^ Cool thanks
Old May 21, 2008 | 04:52 PM
thanks for the pictures redog they really helped. Well this is what i came up with its pretty dirty and of course the 2nd number is the hardest to read but im pretty sure its 34R16378 or maybe 34B16378? Any info anyone?
Old May 22, 2008 | 10:59 AM
Redog's Avatar
3= Oldsmobile motor
4= 1974
B= Baltimore
R= ??
16378= last 6 in the VIN the car the motor came out of, BTW you're missing a number
Old May 22, 2008 | 11:27 AM
Opps. Ok so it looks like 34B163758. Im still not too sure if its a B or R but if there is no plant begining with R then i guess its a B. When i buy parts for my engine i should now look under a 1974 350 4bbl right? How can i tell what kind of car this engine came out of?
Old May 22, 2008 | 01:47 PM
R = Arlington, TX. No Oldsmobiles were built in Baltimore in 1974. By the way, H/Os were built in Lansing, even in 1974, so tell the seller he's full of horse puckey.
Old May 22, 2008 | 05:02 PM
Thanks. I figured that it wasnt and dont care much for the guy who sold me it anyways. My only real concern is when i buy parts i want to know what engine i should be telling them i have.
Old May 22, 2008 | 10:32 PM
Brett4777's Avatar
while you guys a filling engine id blanks can anyone tell me what size my engine is and what year it is plus what my chassis number means
http://www.shannons.com.au/auctions/...4SAYJDD215B05L
apparently my car came into Australia in the 60s
Old May 23, 2008 | 06:59 AM
Jim's rare 80's Avatar
Jim's rare 80
That number is a 68-72 block. Look for the head id # obove the center exhaust manifold on both sides.,
Let us know.
Old May 23, 2008 | 07:01 AM
Jim's rare 80
OOOPs
http://www.oldspower.com/vb/showthread.php?t=11919
Forgot to put this in.
Check the link at the bottom of this page.
Old May 23, 2008 | 11:13 AM
Let us know.
That casting number was used for 68-76. Don't believe everything you read in the FAQ.
boondocker
Non-Olds Engines
Dec 10, 2011 06:06 AM
hunter
Oct 11, 2011 12:09 AM
wildwillie1981
Jan 17, 2010 04:42 PM
jeffreyalman
Jun 6, 2009 06:28 PM
