intake/carb question
Old Mar 3, 2008 | 02:27 PM
dan2286's Avatar
I have an Olds 350 with an Edelbrock intake and Holley carb. I can not get the trans cable on witout it hitting the EGR port. I have an adaptor/spacer plate intalled also. Is their different brakets I can use on the carb, or will it not work at all. I hear about people using Holley carbs on those manifolds, that is why I went with that. Also the cable bracket will not fit the carb studs, is there another one that will fit? Hopefully you guys can help me out, because the people at Summit Racing have no idea about Olds engines.
Just so you know engine is going into an 86 Cutlass.
Thanks so much for the help!!
Don R
Oct 6, 2012 09:47 AM
RandyS
Oct 4, 2012 12:36 PM
svnt442
Jul 17, 2011 04:43 PM
