olds 307 chevy 350 swap
Old Jan 21, 2008 | 03:27 PM
wdm3000's Avatar
Angry olds 307 chevy 350 swap
gotta problem friend gave me chevy 350 when he totaled his camaro cause i needed a motor for my 84 custom cruiser well after much work and toil i found that the mounts and tranny do not match up i know the gm mounts or that era were bolt in so new engine mounts will be no problem my question comes to will the 200 r4 hold up to a 450hp motor or will i have to get a new tranny and torque converter if so how hard are the tranny swaps
Old Jan 21, 2008 | 04:32 PM
EVERYTHING is different - motor mounts, trans (possibly, unless you have a unisex 200-4R), accessory brackets, manifolds, etc. The A/C and starter are on opposite sides and require rewiring/replumbing. The easier solution is to sell the Chevy and buy an Olds 350 or 403.
J-(Chicago)'s Avatar
Seasoned beater pilot.
That trans will work, but you will have to get it built up. Do a search on here there are several posts about it and the builder I think his name is Brian Hofer. Also you will need a trans bolt converter plate because B.O.P transmissions will not bolt right up
Old Jan 21, 2008 | 09:38 PM
Originally Posted by J-(Chicago)
...Also you will need a trans bolt converter plate because B.O.P transmissions will not bolt right up
Actually, I think all 200-4R transmissions have the dual bolt pattern case.
Old Jan 22, 2008 | 01:58 AM
BONUS!
Old Jan 22, 2008 | 12:04 PM
88 coupe's Avatar
Junior Member
........ found that the mounts and tranny do not match up ........
http://gbodyforum.com/viewtopic.php?t=2901
Norm
Old Jan 22, 2008 | 12:12 PM
88 coupe's Avatar
Junior Member
........ will the 200 r4 hold up to a 450hp ........
Your friend gave you a 450 HP Chev engine?
Norm
glendalegearhead
Jul 5, 2015 11:25 PM
falconsfan
May 14, 2015 05:47 AM
Jolds86
Dec 16, 2014 07:49 AM
jonlewis09
Nov 25, 2013 12:58 PM
deltaroads
May 14, 2011 08:54 AM
