reving an Olds 350
Old Jun 29, 2007 | 10:22 AM
GoldOlds's Avatar
reving an Olds 350
With such a short stroke, why can't the 350 Olds be reved as high as a Chev 350? I'm not trying to be a jerk, I'm honestly just wondering. Is it insufficient oiling for the bottom end?
- GoldOlds
Old Jun 29, 2007 | 04:16 PM
88 coupe's Avatar
Junior Member
Originally Posted by GoldOlds
........ why can't the 350 Olds be reved as high as a Chev 350? ........
I don't know that it can't. I also don't know that it would be productive, in any given circumstance.
........ I'm not trying to be a jerk ........
There is no reason for anyone to think so, since, asking questions, is not a qualification for being a jerk.
........ Is it insufficient oiling for the bottom end?
Not a factor.
Norm
Old Jul 16, 2007 | 02:34 AM
The_Jeremiah's Avatar
The only reason i can think of, is the pistons sit at a larger angle outwards from the center of the engine, comparatively speaking to a chevy 350
Old Jul 16, 2007 | 06:23 AM
Both 350s use a 90 degree angle between the cylinder banks - as do most V8s since this provides a natural dynamic balance (note that weird V8 configurations like the 60 deg V8 used in the second gen Taurus SHO need balance shafts).
There are a number of things that limit peak RPM. Bottom end strength (4 bolt mains vs. 2 bolt, for example), bearing speed (Olds motors have larger diameter main and rod bearings, which increases the linear speed for a given RPM), reciprocating mass, rod strength, valvetrain float, and head port flow. You can certainly build an SBO that matches an SBC for power at a given RPM. AJ Foyt ran a 350 Olds (NOT a diesel block, by the way) in a Cutlass in NASCAR in the mid 1970s. That's why CJ Batten developed those aftermarket heads in the first place.
Nor Cal Andy
Nov 27, 2012 10:33 AM
ROCCETMAN
Oct 20, 2009 06:04 PM
dharlett
Sep 23, 2009 03:30 PM
Jokers69
Oct 5, 2006 03:00 AM
