no oil to top end
Old Jun 13, 2007 | 12:05 AM
mr-tom's Avatar
no oil to top end
69 350 lifters started making noise the other day checked the oil pressure i have 60 psi at hi indle goes down to 40 psi at idle push rods are clear any one have any idea what could be the problem
Old Jun 13, 2007 | 09:30 AM
Not knowing the internal condition of your motor, one can only guess. The oil pressure tap on the Olds motor is at the end of the lifter gallery, so you'll have at least that pressure feeding the lifters. The pressures you're seeing are normal. The other options are gummed up lifters, worn valvetrain parts, or worn cam.
Old Jun 14, 2007 | 11:04 AM
Oldsmaniac's Avatar
Is it the lifters or the rockers?.....maybe only a worn rocker or 2?.....Oil doesnt squirt out of the pushrods in large amounts....it just sorta dribbles up thru as the RPM increases there is more oil.....at idle there isnt a lot of oil that you will see at the rockers.
Old Jun 14, 2007 | 09:41 PM
mr-tom's Avatar
its just one on side just drippels out at idle & hi rpm looks like its hade that problem ever since it was new valve cover on that side looks like new compared to the other side just putting in new lifters and changing the rockers on the side with no oil hopfully it solves the problem rockers are badly worm so im crossing my fingers have a guy comming to buy it on saterday
Old Nov 30, 2008 | 04:27 PM
The_Jeremiah's Avatar
Same thing happened to mine. good psi, but no oil at the pushrods, dont know why its doing this, cam bearing or blockage, cant think of anything else
350TurBRO
Sep 12, 2014 11:52 AM
Kidcutty
Jan 19, 2010 06:35 AM
Uly49
Nov 3, 2009 11:45 AM
y30786
Nov 9, 2006 01:23 PM
