Larger cam (or not)
Old Feb 14, 2005 | 02:04 AM
Mike Hathaway's Avatar
Red face
I have a 93 GMC Safari that is powered by a OLDS 350/4L60E and the ECM/TBI of a 94 chevy truck. I was given an Isky .512 lift cam,never used,and wondered what would be needed changed to run this cam. The engine is now 9.5:1 and .448/.472 and I know this is radical,let me know if I can make the switch or should we run this cam in the cutty with a carb instead=.472/.496 & 8.5:1 now . [img]redface.gif[/img]
Old Feb 14, 2005 | 11:21 AM
Oldsguy's Avatar
Past Administrator
Post
Mike, that lift sounds pretty steep, you may find you wont have enough vacuum to operate your brakes safely if the duration is also big. Is that cam a torque cam? you might check the specs on that cam out before using it in the GMC. It might be a better cam for the Cutlass if you plan on using the car as a "toy". Also, check with the people over ar ROP. They are quite knowledgeable and will be more than willing to help. Good luck.
Old Mar 23, 2005 | 08:12 PM
Post
Thanks for the help,but I chickened out and sold the cam for $60,fear of problems overran my courage to try,thanks again Mike
Ctott70
Jul 17, 2022 05:16 AM
AzChevs
Nov 8, 2013 10:33 AM
dfire25
Jul 10, 2013 09:37 PM
brokeandugly21
Ninety-Eight
Apr 23, 2011 01:24 PM
The Stickman
Mar 16, 2010 07:34 PM
