Engine/heads?
Old Dec 27, 2006 | 07:27 PM
ZASX's Avatar
Engine/heads?
Need Help Figuring Out What Engine Ive Got Its Marked3955582the Heads Are Marked Cfd,409,147,112,113 Thanks If Anyone Can Help
Old Dec 27, 2006 | 08:59 PM
Redog's Avatar
The 2 being the last number means it's a 1972 motor and 395558 is the casting on the Olds 350 motors from 1968 to 1972.
The heads will have a large number by the #1 plug wire. That is what heads it has
Old Dec 28, 2006 | 07:06 AM
ZASX's Avatar
Heads
The Number On The Heads Are #7 Are These Any Good? Thanks Again
Old Dec 28, 2006 | 07:18 AM
Redog's Avatar
5, 6, and 7 heads from that year are all pretty good.
There are mixed reviews thought, some will say 5 are the best, others will say the 7. 6 are the rare ones
Old Dec 28, 2006 | 03:01 PM
texasred's Avatar
Tom Servo's Stunt Double
5 is supposedly the best flowing stock heads. 7s are the first year that "should" have hardened valve seats for unleaded fuel. I've got ported 7s and they do quite nicely.
C.J.
Old Dec 28, 2006 | 04:42 PM
ZASX's Avatar
Parts
Thanks Everyone For The Info On The Engine&heads,where Is A Good Place Too Order Parts?1972/442 Thanks Again
Old Dec 28, 2006 | 05:04 PM
texasred's Avatar
What kind of parts?
Most everyone is good...except for Mondello and a couple of "Brothers". (I can't say the name of the "Brothers" company because they have taken legal action against some folks who got screwed by them and then had the audacity to complain about it on Oldsmobile boards.)
Just say away from Mondello and the "Brothers" (whose company I can't publically name).
C.J.
Old Dec 29, 2006 | 10:36 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Depending on what you are looking for, you should be fine with the 7 heads. The 7 heads are from a 71 and 7a's are from a 72. The 7a's definitely have hardened seats but I am not sure about the 7's. Both heads have small combustion chambers which is what you want. The 72 used dished pistons to lower the compression to 8.5. The use of flat top pistons will raise the compression which will be offset in part by the thicker head gaskets available today. Hope this helps.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
805cut
May 3, 2012 08:11 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
