intake, carb suggestions
Old Aug 2, 2009 | 06:07 AM
70redvert's Avatar
Machine shop just finished my '70 350 rebuild. Mild cam, flat top pistons. I am looking for a intake and carb set up for it. Any suggestions for a car I am planing on driving maybe 3-4 days a week. I will also need vavle covers and was wondering if Edlebrock had valve covers with what I'll call fins on them. I had some M/Ts on my '69 Camaro way back when.
Old Aug 2, 2009 | 06:13 AM
Bobsw32's Avatar
BobsW32
Intake and car
I would run an Edelbrock performer intake and a Quadrajet car..... Quadrajets are great on the street with their small primaries... The Edelbrock will help reduce weight and look cool......
Old Aug 2, 2009 | 08:55 AM
captjim's Avatar
If it has flat top pistons and the original #6 heads, the compression ratio is going to be pretty high, probably a little over 10 to 1. That would probably make the RPM a better choice, IMO, depending on the cam, converter and gears. Q-jet is a fine carb for a driver, and will probably get a little better mileage. Holleys work well too, and there are E-brock proponents. It is really a personal choice. I really like the M/T calve covers. I paint them the same color as the engine, then polish the M/T and the raised ribs. Looks sharp, IMO.
Old Aug 2, 2009 | 10:54 AM
Wireman134's Avatar
RPM a better choice, either way, with steel factory head gasket @ 10:1CR or a aftermarket .040" @ 9.5:1CR. Try to shoot for between 7.5:1- 8.5:1 (say 8:1 target) Dynamic compression ratio for a street engine. Enter your engine specs into this calculator.
http://www.projectpontiac.com/ppsite...nt/view/16/30/
Old Aug 2, 2009 | 11:28 AM
70redvert's Avatar
Does edelbrock make valve coverswith ribs for oldsmobiles? Also what about an up grade in the distributors?
Old Aug 2, 2009 | 11:35 AM
captjim's Avatar
9.5 is on the very low end, IMO. I'm assuming Speed Pros, which have been .024 +/- in the hole on undecked engines that I have done. If there has been any milling of heads or block, Cr could easily be over 10.2. Nice link on the calculator. It depends on whether he measured everything and the cam, but I agree that either way the RPM should work better.
As for distributors, you can install a Pertronix kit in your points unit or get an HEI, don't waste your money on a high dollar after market unit, IMO
Old Aug 2, 2009 | 12:05 PM
The Stickman's Avatar
At the moment I am running a Mallory Unilite with an MSD coil and it definately made a difference. But I have a Bilet MSD distributor waiting in the wings but need a box to use it.
F15david
Aug 7, 2012 05:34 PM
TheNewGuy
Feb 26, 2012 06:03 PM
svnt442
Jul 17, 2011 04:43 PM
66starfire
Dec 27, 2006 09:10 AM
