Oil Sending Unit
Old May 18, 2009 | 04:05 PM
bcg88's Avatar
Oil Sending Unit
Hey guys
This weekend my oil light came on while driving home. At first it glimmered a bit at idle at a light. As I accelerated it got brighter. When I took my foot off the gas it dimmed then went out. After a 1/2 mile it came on and stayed on the final 1/2 mile home. I eased her home and shut her down.
The sender was replaced about 2 years ago. I pulled it and it looked ok. I plugged in an oil pressure gauge from a friend and started the engine back up. It indicated strong oil pressure when revving (over 40-50 LBS PSI).
Thoughts on next steps? It seems I am getting good oil pressure per the Stewart Warner gauge I plugged in. The oil pump is also new about 2 years ago. I replaced the 40 year old original when fixing an oil pan leak. It has run fine for all of that time. The wiring is original going to the unit.
Old May 18, 2009 | 05:18 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I vote for the sending unit. I think the bad ones and the good ones all look alike. They are cheap. The gauge won't lie. Go get a new sending unit, put it in and I bet your problem will be gone. Could be wiring but doubtful.
TheRuss
Sep 30, 2025 05:33 AM
Ron King
Dec 20, 2009 12:58 PM
oldsvair
Nov 16, 2008 03:10 PM
boese1978
Jan 22, 2008 11:56 AM
