Dipstick removal
Old Feb 7, 2009 | 10:42 PM
smcurro's Avatar
Dipstick removal
Any good tricks for getting the dipstick out of a block..preferably without destroying it? It seems to be rusted in there pretty good... I have the block completely torn down. Thanks
Old Feb 8, 2009 | 05:21 AM
csstrux's Avatar
Its press fit int the block, mine came out fairly easily with a bit of coaxing. If yours is tight you might want to try a little bit of localized heat on the block, and a pliers, that wont crush the tube(curved jaw).
Old Feb 8, 2009 | 07:07 AM
The Stickman's Avatar
I got under the lttle lip with a screw driver and tapped it out with a hammer.
Old Feb 8, 2009 | 08:35 AM
If you have the block completely torn down, you should be able to tap it out from the bottom. To answer the more general question, the only method I've found to reliably get the tube out without damage is to use a slide hammer. I fabricated a piece that screws into the end of my slide hammer and just fits into the upper end of the tube. I clamp it in place with a vice grip pliers on the outside of the tube and use the slide hammer to extract the tube. 100% success to date with no damage.
Old Feb 9, 2009 | 08:21 PM
smcurro's Avatar
great suggestions, thanks!...I think I'll try the slide hammer idea first
dantecl
Oct 27, 2013 02:50 PM
Jolly Green
Jan 16, 2013 05:07 PM
dan2286
Aug 18, 2010 09:44 AM
scubastever
May 15, 2008 06:13 AM
dan2286
Mar 15, 2008 02:56 PM
