Timing Marks
Old Jan 23, 2009 | 07:48 PM
Gbobby's Avatar
all olds...all the time
Timing Marks
Can anyone tell me the proper way to allign timing marks on a 350 or 403 when Removing & installing a cam or timing chain?
Old Jan 24, 2009 | 05:59 AM
Since the cam rotates at half the crank speed, either way is correct. Either both at 12:00 or crank at 12:00 and cam at 6:00. Of course, you still need to make sure the distributor is installed with No. 1 firing on the compression stroke, not the exhaust stroke.
Old Jan 24, 2009 | 06:23 AM
Gbobby's Avatar
There are 2 timing marks on my crank sprocket. Is the correct timing mark the one to the left of the shear pin or to the right?
Old Jan 24, 2009 | 08:44 AM
88 coupe's Avatar
Junior Member
There are 2 timing marks on my crank sprocket ........
What manufacturer and part number?
Norm
Old Jan 24, 2009 | 08:58 AM
Gbobby's Avatar
The crank sprocket that is in the 350 has 2 marks on it. It seems to be original because it still has the plastic like cam sprocket on it. 1 is to the left of the shear pin and the other is to the right. I am in the process of tearing the 403 timing cover off so I don't know if that is the same way or not. The new one I bought from coyles just has the 1 mark to the left of the shear pin so I guess I just answered my own question. Any advice on getting the crank sprocket off without damaging anything?
Old Jan 24, 2009 | 07:55 PM
88 coupe's Avatar
Junior Member
Regular gear puller.
Norm
Old Jan 26, 2009 | 07:13 PM
Danny Wiseley's Avatar
>snip< Any advice on getting the crank sprocket off without damaging anything?
On my '79 350, I had to pull the key out of the crankshaft before the sprocket would come off. Slot in sprocket doesn't go full width.
DW
Old Feb 4, 2009 | 06:31 AM
Gbobby's Avatar
Got the timing chain in the 403 and timed it. Soon after that the lower end started knocking. I have shipped my 350 out to be machined and will be rebuilding it as soon as it gets back. Thank you for all of your help and I have learned that its always good to have a spare engine hanging around!
Carshinebob
Sep 11, 2013 04:06 AM
willj
May 18, 2010 02:09 PM
bullet1
Sep 25, 2009 05:44 PM
cisco88
Oct 17, 2008 07:12 PM
MIRADAMANia
Apr 22, 2008 01:00 AM
