'70 98 Front Trim pieces needed
Old Nov 7, 2008 | 03:08 PM
Oilbrnr's Avatar
I'm looking for the Ninety Eight script and short spear shaped trim piece that goes beneath the script for both front fenders.
They were lost and/or destroyed during a recent repaint.
Old Nov 8, 2008 | 07:04 AM
Oldsguy's Avatar
Past Administrator
Hope you can find replacements or the originals someplace. Welcome to our site.
Old Nov 9, 2008 | 04:53 PM
rocwal
Guest
Posts: n/a
7o 98 front trim pieces
I have a 70 98 4 dr HT ,let me look tomorrow and get back to you on the spear's. I know I have the ninety-eight scripts they are the same in67-68-69-70 <I know cause I collected them for the restoration of my 68 98 convert.
rovwal
Dan B
Old Nov 10, 2008 | 09:59 AM
Oilbrnr's Avatar
Thanks for looking!
Dan, do the fenders need to be removed in order to attach these pieces? Honestly I haven't looked yet. I'm assuming that they use the typical trim speed nuts.
Old Nov 10, 2008 | 03:16 PM
rocwal
Guest
Posts: n/a
70 98 trim peices
Not if you have a long thin arm, You can reach down inside the fender ,I have used a 1/4 inch drive long socket to take them off but never put them on this way The scripts should go OK ,but the spears are attached thru the fender support by the door it would be a lot easyier if you could remove the lower fender to frame bolts and pull the fender out away from the door install the spears and then adjust the fender .
I do have several sets of ninety-eight scripts very good,good,and to fill the holes. the spears have small corrosion on the tops but can be installed with that down and touched up with silver paint , "you " would know it was there or have them rechromed they are in pretty good shape let me know and I will PM you with cost.
rocwal
Dan B
oldspackrat
Apr 4, 2014 09:39 PM
costpenn
Dec 20, 2012 09:01 AM
dennisspeaks
Oct 3, 2011 07:36 PM
capjr
Jul 29, 2009 04:57 AM
