Instrument Panel Parts
Old May 9, 2006 | 08:29 AM
1966Dynamic88's Avatar
I'm desperately trying to find a part for my 1966 Dynamic 88...can anyone help? On the instrument panel, the back of the box that has the various push buttons for the fan, heat, ac, etc. shorted out. Since the system is mechanical/vaccum operated, when the wires/plates shorted out and welded together I can't fix it....so I'm trying to find a replacement cluster/box. I've tried junk yards with no luck. I also need to find a replacement fan switch for the instrument panel. Can you recommend talking to anyone? Thanks!
Old May 9, 2006 | 11:48 AM
Oldsguy's Avatar
Past Administrator
I responded to your pm.
Old May 13, 2006 | 08:39 PM
luv2race's Avatar
66 olds parts
[I don't know if you have found what you are looking for or not, I am going to part out a 66 olds, maybe some parts you can use? Car only had 15,218 miles on it, has sat 38 years, I will look if you are still in need, let me know, thanx Jamie
Old Oct 12, 2006 | 10:01 AM
teto1977's Avatar
i was wondering if u would have the passenger door window that i can buy, i have a 66 starfire which should be the same.
Old Oct 14, 2006 | 06:56 AM
luv2race's Avatar
door window
I have a 1966 olds 98 four door, if there is anything you might think useful, let me know, I am not sure what all interchanges between the starfire and the 98, but if you know it will interchange I will help you any way I can, thanks, Jamie
Old Oct 20, 2006 | 07:35 PM
dynamic88's Avatar
you might check usa parts supply in manassas,va 703-335-1935 they carry parts for olds 1941 to 1975
rroth01
Dec 23, 2023 04:35 AM
patmills
Mar 5, 2010 12:39 PM
rroth01
Mar 1, 2009 06:04 PM
John G. Nelson
Dec 9, 2008 08:52 PM
1966Dynamic88
May 9, 2006 11:51 AM
