Wanted '59- '60 power window relay
Old Apr 25, 2008 | 08:30 AM
59-59-59's Avatar
Wanted.. Power window relay that sits on the firewall and is held in place with 2 phillips screws. Mine literally fell apart in my hand into 4 pieces .Also power seat switch for a 2 way seat.. Thanks
Old Apr 25, 2008 | 09:07 AM
Oldsguy's Avatar
Past Administrator
If you aren't restoring your car you could use a modern relay. The original had three contacts correct? One for 12volts to operate relay, one for the motor and one for the ground (maybe only two contacts if the relay was metal and the ground was the case to the firewall). Check the amperage requirement of the motor by checking the size of the fuse on the circuit the power windows are on (could be 15A) and then get a relay rated for that size load. They are available at most auto parts stores although many of the new ones are in black plastic housings and have the third contact. Same would apply to the power seat.
File Type: jpeg
Old Apr 25, 2008 | 11:51 PM
59-59-59's Avatar
I screwed up... I meant the circuit breaker on the firewall, which was readily available at NAPA ( I was shocked ) that was identical to the one on the car. I got away cheap - about 4 bucks
pcard
May 14, 2014 01:21 PM
ent72olds
Aug 16, 2012 03:28 PM
ent72olds
Aug 10, 2012 06:28 PM
projectheaven
May 24, 2012 08:42 PM
jugdish
Aug 18, 2011 09:57 AM
