Wanted Tilt Tele Steering column 67-68 Olds 98.
Old Apr 11, 2011 | 06:07 AM
Rex's Avatar
Rex
Need a steering column from a 1967-68 Olds 98 with or without wheel.
Rex
Old Apr 11, 2011 | 06:09 AM
2blu442's Avatar
Hi Rex
I do have a black non-tilt, column shift column that I pulled from a 1968. If your interested I can get photos for you in the next couple days. John
Old Apr 11, 2011 | 06:26 AM
Rex's Avatar
Rex
John, this is a tilt, telescoping unit I need.
Rex
Old Apr 11, 2011 | 06:30 AM
66400's Avatar
Rex
If you come to Austin I have two 67 Olds 98 parts cars. One black, one turquoise. Henry
Old Apr 11, 2011 | 06:34 AM
Rex's Avatar
Rex
Henry, that may be possible. Let me check my schedule and see what I can do.
Thanks, Rex
Old Apr 11, 2011 | 06:49 AM
2blu442's Avatar
OK, I added Tilt Tele to your title. That may weed out people like me with only a standard column. John
Old Apr 11, 2011 | 06:54 AM
Rex's Avatar
Rex
Thanks John,
Rex
Old Apr 12, 2011 | 11:16 PM
rocketray's Avatar
In my stash of Olds steering columns I believe I have a tilt tele from a '67. Column shift without wheel. I think it did it's wiring harness, turn and neutral safety switches still intact. I'll confirm in the light of day. Does your car have cornering lamps? (different switches/wiring then non cornering lamp equipped cars)
Old Apr 13, 2011 | 04:14 AM
Rex's Avatar
Rex
Yes rocketray, it does have cornering lightsRex
Old Apr 13, 2011 | 07:17 PM
rocketray's Avatar
Confirmed, I do indeed have (has 4 way flasher built in), black in color. No wheel or levers.
It's not the prettiest though and I cannot determine whether or not it will support a cornering lights equipped car. It does have an 8 wire ribbon type cable with an ID band label BPN if that helps shed any light. $100 + postage and it's yours. PM me I can send pics if you want.
Old Apr 13, 2011 | 07:45 PM
66400's Avatar
I looked at my 2 98's today and the both have non-tilt columns, one does have the corner lamps. Henry
Old Apr 14, 2011 | 05:17 AM
Rex's Avatar
Rex
Rockertray, mine also has the BPM label and 8 wire plug. PM sent.
Old Apr 19, 2011 | 12:27 PM
Rex's Avatar
Rex
Still haven't found one yet. If anyone knows where I might locate one, would love to hear from you.
Thanks, Rex
Old Apr 20, 2011 | 05:20 AM
ROCKETMAN269V's Avatar
Smile Wanted Tilt Tele Steering column 67-68 Olds 98.
I have a black tilt & travel column/wheel out of a '67 Toro, if that might work. My interchange book only goes back to '70 on steering columns. Anyone know if it'll work? I'm in south Florida. Thanks, Bob.
Old Apr 20, 2011 | 05:35 AM
Rex's Avatar
Rex
Thanks Bob, just before your post I got a message from Buickfarmer that he had one from a Delta 88. If for any reason this doesn't work, I will be back in touch with you.
Thanks a bunch,
Rex
ros6872
Mar 28, 2014 09:48 AM
JOE CAPP
Oct 16, 2012 07:02 PM
pontiac
Aug 1, 2012 05:01 PM
nova7579
May 5, 2011 08:44 PM
Dougdawg
Jul 6, 2010 04:17 PM
