2bbl-4bbl swap
Old Dec 1, 2008 | 07:06 PM
ent72olds's Avatar
Registered Luser
Question 2bbl-4bbl swap
Other than a different throttle bracket, is the throttle cable different from a 2-4 bbl. Tranny is a th-350. I did this swap on my '72 cutlass and used a quadra-jet with no problem should it be as easy using a edelbrock(weber) 4bbl on a '70 vista...
Old Dec 1, 2008 | 07:14 PM
Yes, the cable is different. You can buy one on the web used cheap or buy a new one for about 25 bucks. I changed my 2bbl to 4bbl. Other than the intake, carb, gaskets and throttle cable it was pretty much no problem. Don't forget that the 2bbl air cleaner also won't fit the Qjet. Need one designed for 4bbl.
Tim305
Apr 25, 2014 03:37 PM
Tim305
Feb 17, 2014 04:37 PM
boese1978
Apr 23, 2012 07:46 AM
sykosoft
Feb 16, 2012 08:35 PM
cutlass1972s
Jul 6, 2010 06:33 PM
